DodgeIntrepid.Net Forums - Dodge Intrepid, Concorde, 300m and Eagle Vision chat
DodgeIntrepid.Net Forums - Dodge Intrepid, Concorde, 300m and Eagle Vision chat (http://www.dodgeintrepid.net/forums/index.php)
-   Street Stories Etc. (http://www.dodgeintrepid.net/forums/forumdisplay.php?f=27)
-   -   Played with a Porsche 944 (http://www.dodgeintrepid.net/forums/showthread.php?t=16077)
2001RT 01-23-2003 01:56 PM
Before I start - I know that even the lowly wanna-be-a-real-Porsche 944 could toast me if the driver wanted to...
I take about 10 miles of back roads before hitting the highway. I love cranking through the 30mph turns at 60 - 70 when I don't have some dodo in front of me... There are three legal passing sections...
So there I am stuck behind a pickup truck approaching the first passing section. Just before the section the Porsche 944 turns out in front of the truck. The truck flashed the Porsche, the Porsche took off and a few moments later, I blasted by the truck to chase down the Porsche...
I caught up to the Porsche and we cranked through the next section at 50 - 55... However, he wasn't getting on it like I knew he could. So... just for the **** of it, I passed him in the second passing section! Obviously, it was his choice, but it was fun! :D
Of course, there was a penalty... I immediately got stuck behind a mini yellow school bus doing 25 and had to mope along behind it until the third passing area.
Not too wild a story but it was fun!
1mz-fe 01-23-2003 02:47 PM
porsche 944s are really slow. something like 17.0 in the quarter. i'll bet they handle ok and they probably are good up high, but they're really bottom of the barrel porsche cars.
TehKing 01-23-2003 04:15 PM
Bottom of the barrel? Hardly.
The 944 was the direct descendant of the 924 Carrera series and ultimately the earlier 924/931.* Beginning in 1979 and the following two years Porsche began developing racing hybrids based on the 924 which later lead to the 944.* In 1979/80 Porsche built 406 examples of the 924 Carrera GT.* In the following two years, Zuffenhausen continued on to develop several competition versions of the 924 culminating in 1982 with the 924 Carrera GTS (of which 5 were built up as Club Sport models and sold to private owners,) and the limited competition 924 Carrera GTR.* When looking at the Carrera GTS Club Sport, one can immediately see the immanent arrival of the 944.
In order to improve build quality, over the 924 production done at Audi's facility in Neckarsulm, production/assembly of the 944 was done in Zuffenhausen. The power plant was literally derived from half of the 928's V8. At 2479 cc (2.5 liters) the engine was large by four cylinder standards of the day. The engine was a modern design with high compression and a broad power band.* The initial power plant was rated at 163 hp (ROW) and 150 hp for the U.S.
The 944 was originally announced to the world at the September, 1981 Frankfurt auto show with the U.S. introduction one year later. Upon its introduction the interior of the 944 remained much the same as the 924 while the rear suspension, although improved, retained the VW-derived architecture.
In addition to a change in the front suspension control arms, the rear suspension would change with the major revision of the 944 that occurred mid year in 1985.* Often times, owners will refer to there 944 as an 85.5, designating the completely redesigned interior and other improvements to the base 944 including;* new heater, air conditioning, minor revisions to the bodywork including a flush mounted windscreen, new cats aluminum front A-arms and rear trailing arms suspension components.* Although changes where made to the engine, Porsche did not announce any changes to the factory performance specifications.* Practical comparison of this watershed model change and it's predecessors indicates performance gains did result however.
At the end of 1985, Porsche announced the 944 Turbo (factory model designation 951) which arrived in the U.S. as a 1986 model. Performance of the 951 was a reminder of the 944's legacy, even in it's toned down production form.* Aside from the turbo charged power plant generating 217 hp with 243 ft/lbs of torque, the 951 had other major enhancements over it's normally aspirated brother.* Specifically the 951 included aerodynamic polyurethane front bumper/spoiler with new air intakes serving the turbo's intercooler mounted between the headlights under the front panel.* Under body panels where added to cleanup air flow beneath the car.* This extended to the distinctive air diffuser mounted under the rear of the car to cleanup exiting airflow past the rear end. As well, the 951 received Bembo 4 piston calipers to bring the car to a stop as well as special forged alloy wheels.* The suspension received stiffer components to round out the comprehensive performance upgrades.* The 951 also has the distinction of being the first sports car to offer both driver-side and passenger-side airbags.* Porsche also produced 198 versions of the 944 Turbo as Cup racing cars.
The 944S arrived as a 1987 model year addition with a redesigned 16 valve dual overhead cam engine producing 190 hp.* In addition to the increased number of valves and cams, the 944S came with an improved Digital Motor Electronics (DME) system with knock-sensing regulation capabilities.* Also included on the base 944, the 944S benefited from the new timing belt tensioner which was implemented for the 1987 model year.* As well, the 944S received the Bembo brake calipers with optional ABS.* The initial 944S shared the base models bodywork until 1990.
Porsche revisited the 951 and in 1988 introduced the 944 Turbo S with total model year production of 718.* This performance version of the already impressive 944 Turbo received many significant improvements including:* bigger Bempo brakes, ABS, firmer springs and torsion bars, stiffer Koni low-pressure gas adjustable shock absorbers, a thicker front sway bar, and firmer suspension bushings.* The following year, Porsche dropped the "S" designation and the standard 944 Turbo was infact the "S" form factor, building 1385 for 1989.* This was to be the last year the U.S. market would have access to the 944 Turbo.
In 1990 Porsche releases the 944 Series 2, designated 944 S2. The S2 was an extensive revision of the 944S which now included the aerodynamic bodywork of the 951.* The previous three engines available were replaced by the 3.0 liter's 16 valve engine and a big turbo 2.5 liter 944 Turbo (sold in Europe).** As well, a soft-top version of the 944 was introduced, the 944 S2 Cabriolet.* The new cabriolet was produced jointly by Porsche and the German division of the American Sunroof Corporation.
In the fall of 1991, Zuffenhausen announced the Series 3 944, model designation 968.* There was a brief period where what we now know as the 968 was to be designated the 944 S3 but in order to boost slumping sales, the model was marketed under it's factory designation and technically represented the final refined version of the 944 family line.* In addition to further tuning of the 3 liter motor seen in the S2, the 968 debuted with circular headlamps, new nose and rear end.* The interior remained virtually unchanged from the past several years. In addition output of the 3 liter was increased to* 240 hp, resulting in the* most powerful normally aspirated production 4 cylinder available. Performance was primarily gained through the use of a Variocam, a camshaft chain drive with an adjustable tensioned to retard intake valve actuation up to 7.5 degrees.*** Along with the 29 hp increase, torque was also increased from 207 lbft to 225 lbft. The engine also now included piston oil spray cooling from squirters similar to the 911.
Managing the power transfer to the rear wheels was a six speed gearbox (offered as either a ZF or Torsen limited slip differential,) or an optional 4 speed Tiptronic.* The ZF LSD was to be deleted the following year in 1993 with the Torsen version as the only one offered (option code M220)..
As a final testament reaching all the way back to the 924 Carrera Club Sport, the 968 Club Sport version appeared in 1993. The 968 CS included* one inch reduction in ride height, stiffened springs and dampers, fully adjustable suspension, and reduce weight.* As with past Porsche Club Sport models, weight reduction was obtained through deleting luxuries like; air conditioning, power windows, leather seats, stereo, and sound insulation from the passenger compartment.
In actuality a stripped down high performance version of the 968 Coupe, Porsche priced the 968 CS (available only in Europe,) under $60,000, which was considerably cheaper than production super cars of the time. The 968 CS represented the pinnacle of performance and handling for the normally aspirated 944/968.
That being said, Porsche had one final parting pass at the 968 which resulted in the ultimate performance incantation, the 968 Turbo S.* The Turbo S was a rare model only offered as limited production (15 examples total ) available in Europe.* The water cooled KKK turbocharger produced 305 hp (@5,400 rpm) and 369 lb-ft of torque (@3,000 rpm).* Based on the 968 CS, the Turbo S rivaled even the 911 Turbo of that year.
In 1995, with development of the Boxster well underway and set to debut in 1996, Porsche discontinued the 968 bringing to a close the most successful line of Porsche outside of the 911.
In that final year Porsche produced and campaigned a competition version of the 968 Turbo S designated the 968 Turbo RS.* Blisteringly fast with the by now the respected* handling attributes of the 944 S2 suspension architecture, it was a champion from the perspective of performance with some 377 hp.* This would be the final farewell to arguably one of the most underrated Porsche production lines ever.
2001RT 01-23-2003 04:19 PM
Quote:
The 944 was the direct descendant of the 924 Carrera series and ultimately the earlier 924/931. ** SNIP! **
Uh - and that was just off the top of your head, right? I'm just glad you didn't go to the trouble of researching the issue! :D :D :D
Peace...
viprman 01-23-2003 09:01 PM
I never really liked the 944. It seemed to "cheap" to me to be a Porsche. I guess, some could say the same about the Boxster these days.
1mz-fe 01-24-2003 05:14 AM
LHSer just whooped my ass....944 still sucks.
p3 01-24-2003 10:58 AM
Leave it up to Matt to make a moparperformance-length post just to prove someone wrong. ;)
JoeKD 01-24-2003 11:32 AM
Quote:
hella shhhhtttt raw german power yo
p3 01-24-2003 11:39 AM
shhht, scarin' teh 'vettes and Lotuses (Loti?) y0.
JoeKD 01-24-2003 11:42 AM
don't forget to reset your PCM,BCM, ATC, OTIS and ABC modules after each encounter with a porsche
p3 01-24-2003 11:48 AM
You forgot TCM.
crombie 01-24-2003 12:51 PM
Quote:
:eek: :laugh:
bjlv 01-27-2003 03:23 AM
the 944 is a great car...except for the unreliable belt/head design.... at any rate my friend has a 87? 944s. He decided to take me for a ride because I am a huge porsche man, the car is nothing special until about 4500rpms...the agressive cam timing hits its peak efficienty around 5000-5500rpm. that thing hauls ass though. In third gear at about 75mph the engine quit. The chain that goes between the cams in the head broke. He bought the car with head problems... I took him home in my 97 3.5l and ill tell you that my intrepid seemed slow as hell after being in that car.
Ravin 01-27-2003 04:10 AM
Quote:
welcome to the boards bjlv...
TehKing 01-27-2003 07:03 PM
This story is for entertainment purposes only.
DodgeIntrepid.net does not promote or condone illegal activities that can cause personal injury and/or property damage. Any actions documented are solely the responsibility of the author.
Furthermore, readers should refrain from attempting the activities discussed in this story as they could lead to fines as well as prosecution possible imprisonment.
FunkRider 01-27-2003 08:15 PM
Maybe this Disclaimer should appear before entering the Street stories part of the boards and and you should have to check a box saying that you agree with the above statement and by agreeing nothing written can be held against anyone who posts.
Ravin 01-27-2003 08:25 PM
Quote:
good thought. i pondered the same thing.
Foxcow 01-27-2003 09:07 PM
944 are worthless. Its a car for people that want thier cars to say porche but not actlike one. 1/4 mile 16.7 for a 5 speed and 17.0 for an auto. My friends mom has one and that thing is the biggest pile. Half the time I see her, she is trying to get it started. For some strange reason whenever she turns on her cell phone, the car just shuts off. Dont ask me.
Valhalla 21340 01-27-2003 11:24 PM
been a while since the boards, but im gonna have to come on back and side against the 944's.
i dont know what i think of the Boxter...either way we cant afford either anyway so theyre all nice cars. but bout porsche's back alley abortion of a 944, you know the old joke "what the hell is the motor doin in the trunk!"...well, 944..."what the hell is your trunk doin in the back!". and what about the signature Porsche exhaust hum? non-existent. you can just turn your head towards a sound you hear on the eastward horizon and say "...thats a Porsche". maybe im being biased, but the only 944's i see on the road have about as much faded paint as can be, and are usually poorly running example.(and no, im not seeing the same car more than once). this isnt necessarily attributed with the 944 being 'junky' per-se, but it does go to show. I guess it just boils down to the fact that the 911 is Signature Porsche. it still is the flagship car, and (more or less) still looks like a stretched volks beetle, the way a porsche SHOULD look. ok enough about the 944. what about the cayanne?!
bjlv 01-28-2003 10:06 PM
hmmmmm no 17s here, and these quarters seem low to me, must have been at a higher altitude.
0-60 quarter
1982 Porsche 944 8.3 N/A
1984 Porsche 944 9.0 16.4
1986 Porsche 944 8.9 16.6
1986 Porsche 944 Turbo 6.0 14.6
1988 Porsche 944 8.7 16.6
1988 Porsche 944 S 8.0 16.2
1988 Porsche 944 Turbo 6.6 15.1
1988 Porsche 944 Turbo S 5.5 14.2
1989 Porsche 944 7.5 15.7
1989 Porsche 944 S2 6.6 14.9
1990 Porsche 944 S2 6.7 14.7
same site lists
1993 Dodge Intrepid ES 8.8 16.5
1994 Dodge Intrepid 10.3 17.5
1998 Dodge Intrepid 8.9 16.7
of course with different drivers and conditions these numbers will vary. Lets face it...the 944 is a excellent car. Other than the reliability problems with the dual over head cam setup the cars are good cars if they are taken care of. The problem is that the 944 is considered to be the runt of the porsche culture. The timming belt issues have cuases cars to have to under go major repairs and people without the $ have negleted the cars. Also the value of 944s has not held well because of the reliability issue, and the stigma created around them. Speaking of this stigma have you heard of similair problems much on 928s? no becuase the 928s appealed to rich corperate execs since they costed more than the 911 at the time. But the 928 shares the same problem as the 944. At anyrate, unless the car is a automatic, or the driver doesnt know how to drive the car...a stock 944 will beat a stock intrepid. Expecially if the 944 is a later model...
jtatz 01-30-2003 03:59 PM
[/b]
Finally a post that I like! :)
I seriously thought about getting a 944 before I got an Intrepid. Not totally practical, but I thought it would be fun..
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
