I would try the plugs before the coil pack if they're not pretty new. if it only does it when it gets hot, try the egr valve and the metal hose going into the intake, i've seen theese completely clogged at junkyards. and if that's not your problem the only other thing i can think of is oxygen sensors, but if they were bad you would probally get a check engine light, (code 2-1) i think
