I bet you got your wires mixed up check them again and check very well. If the car will idle get out and pull one plug wire at a time. If it makes a difference in how the car runs then that cylinder is firing if not then it's a dead cylinder. Fallow that spark plug wire to it's position and make sure it is where it should be.
