Originally Posted by Justsomeguy
Ok heres one more question before i go out and buy the OPS
Wouldnt the light only flicker or come on when im idling if it was the oil pressure switch? Im starting to think it may be that the oil pump took a dump on me, and thats the reason why 2 days ago when i first started the car i was hearing tapping sounds for about 2 minutes when the engine was first started after sitting overnight
I do not think the pump took a dump-oil pumps either 1) work or 2) do not work they have no in between. I know that if my car sits for more than a couple of days the lifters will bleed out and cause one hell of a racket after i do start it( that last time it sat for a week when the family and I went on vacation-it sounded like a diesel and had a slight miss to it).
There is a TSB for this that replaces either the lash caps or the cam followers(right now I can not think of which it is). My money is on that, not the oil pump.
To rule out the pump I would connect a mechanical gauge and test the oil pressure-if ok
the pump is good. could have a bad oil pressure switch-a piece of crude could be stuck in it.
Tom
