Originally Posted by Dudley
somebody in your area has a remote with the same frequency as is required to pop your trunk.
You can verify that theory (which is most likely) but unplugging your RKE unit.
If you pop up your IC panel, the black panel between the base of the windshield and the top of your dash with the speaker grills in them, on the passenger side between the passenger front speaker and the center speaker, you will see a small black box, a little bigger than a deck of cards. This is the Remote Keyless Entry (RKE) unit. If you look at the unit, you will find some sort of label on it stating that it is an RKE unit. Un-plug this, and your Trunk Spookies will go away if it is what Dudley suggested.
I seem to remember that the RKE is the one closest to the corner speaker on the passenger side...
