07-07-2012, 11:18 AM
Akron |
141 |
And most of the people on these boards actually have a clue when it comes to repairs. I'm pretty much the only chick on the team and as a single, I need to pay for every repair I make!
I haven't invested $1,000 but when i had the Thermostat/Timing Belt/Water Pump crisis, I came close. I also had a liar telling me I needed a head gasket. The Timing Belt was costy but worth it. The head gasket would not have been.
This car had a rebuilt transmission when I bought it. I know cars of this age and style are prone to transmission issues ... why on earth would I get a USED tranny?
I'm still of the firm hope that it's a quick and easy fix.
07-07-2012, 12:01 PM
1,404 |
Diagnosing from the PC is a crapshoot at best. Here's hoping you get an answer that agrees with your situation. I was simply basing my opinion on the symptoms you described. Best of Luck!
07-16-2012, 09:21 PM
Akron |
141 |
Well I took the car to a transmission shop. Unfortunately, it was a nice, cool day. And you know how the tooth doesn't hurt the day of the dentist appointment? It was kind of like that.
So he seemed more focused on a cheap fix than an accurate diagnosis. Said it threw a "mess of codes" but only 2 were transmission related. He "re-learned" them, whatever that means. Added a pint of fluid even though it wasn't really low. And told me to call if it happened again. Also, the steering was "spooky." I will post a separate rant about that.
The next day, while driving it back and forth to the alignment shop to resolve the "spooky steering" issue, it had a bit of a hiccup on the way to work. I was accelerating on a main road. The RPM went up to 2,000. And the spedometer was firmly stuck at zero. About 10 seconds later it jumped to 30.
But since I haven't driven in the heat too much, it has been relatively problem-free. It did seem to be acting up just a bit on the way to work today.
I have a sinking feeling it's an electrical issue of some sort. A friend mentioned that she once had a car that did the same thing. It wasn't a transmission, but she couldn't remember what it was.
Once I solve the "spooky steering," I may put it on the market. It has run like a champ over the past year, but with the steering and front end issues, and the oversensitivity it has to heat since I replaced the thermostat, water pump and timing belt and now this, it's probably not worth keeping. But I really can't think about car replacement til spring ...
07-16-2012, 10:11 PM
1,404 |
So, are you saying the car was already moving and you tried to accelerate to a higher speed? Is this when the speedo went to zero?
If so, that would be an indicator of an output speed sensor on the transmission. The engine controller gets it's speed signal from the transmission controller which is hard wired to the output speed sensor. Once the engine controller gets the signal it relays this to the instrument cluster where it is changed from an electrical signal into a physical meter reading, (In this case the speedometer.) If the source signal is not there then all the related issues can occur
Yes, you may have a wiring issue but, I'd bet the output speed sensor on the transmission may be having connection issues or, is failing.
I would try an OSS and see if the symptoms are resolved. (20 - 30 bucks + installation)
07-16-2012, 10:44 PM
Akron |
141 |
I don't know what an OSS is but wouldn't it have thrown a code, even if it wasn't doing that problem that day?
It never MOVED from zero from the time I was stopped at the top of the street until it finally jumped to 30 a few blocks down the road. It was the first time it's EVER done that, and I suspect the heat and the fact that I'd already driven it 40 miles or more that day had a lot to do with it. I put a speed sensor in it when it was stuck in 2nd gear.
Other than that incident, its hiccups seem milder and further in between. I've also taken pains to drive it shorter distances. But it did also seem to be "panting" by the time I got to work this afternoon. (A distance of about 18 miles, 10 of it highway.)
07-17-2012, 04:39 PM
1,404 |
OSS = Transmission Output Speed Sensor.
07-17-2012, 04:52 PM
Akron |
141 |
Since they checked the codes, I am thinking this is one of the ones it threw at the Tranny shop.
Since they "re-learned" the codes last Wednesday it has done this maybe 5 times. ALL on days when the heat exceeded 90, ALL on days when I was doing a lot of stop and go driving, ALL on days when the heat needle was around 50 percent. It hasn't done the thing with the spedometer since last week. Mostly, it's hesitant to get going at a stop sign but goes anyway.
When I replaced a speed sensor last year, the car remained firmly stuck in 2nd gear.
So would transmission sensors be sensitive to the heat? If so, could those "transmission cooler lines" have anything to do with it?
07-17-2012, 07:42 PM
1,404 |
I'm not sure what was meant by "Re-Learned the codes"
You can read and erase codes with a scan tool. You can re-learn the adaptive memory of the transmission controller, (Frequently called a "Quick-Learn"), with an advanced scan tool or DRBIII.
I'm trying to correlate the ambient temperature to the symptoms and I am coming up blank. Except possibly the transmission temperature sensor which is an internal part.
The leaking cooler lines are not something you want to put off for very long since they will cause complete transmission failure if the fluid drops too low for an extended period. Not to mention funky shifts along the way.
I just overhauled a 42RLE transmission in a Jeep wrangler today. This transmission has many of the same basic characteristics as yours, including a low tolerance for neglect. don't take this wong, I'm not saying you're neglectful but, leaks must be addressed promptly. This Jeep had only 27K on the odometer.
07-17-2012, 08:12 PM
Akron |
141 |
I'm not sure either but they said something along the lines of taking them back to factory specs and said that it may run differently as it gets used to my driving again.
I never said the lines LEAKED. I said another mechanic noticed that the lines to the TRANSMISSION COOLER looked a bit old. Probably that they weren't replaced when the tranny cooler was.
In the entire time I have owned the car, the transmission fluid has NEVER gone too low.
I am thinking it's not related to the transmission so maybe I should change the title of this thread if I can. It only does this on hot days. If it's 70 or 80 degrees, it runs just fine. When it's 90, it also "pants" just like the rest of us. And occaisionally doesn't like to get moving after a stop. Again, much like the rest of us.
08-02-2012, 04:44 PM
Akron |
141 |
Just wanted to say thanks all. I did some more research on the spedometer issue and am more convinced than ever that it is an "output speed sensor." Tranny shop can't get me in til next week, so I am going to replace it on my only day shift.
It scared me quite a bit when it also was stuck in second gear for a while.
Tranny guy tells me there are 2 speed sensors, input and output. I replaced the input 2 years ago at a cost of $43, including installation and tax.
08-02-2012, 06:21 PM
That rhythm is INFECTIOUS. |
Pickerington OH |
16,884 |
Wow - $43 installed is quite a deal. I hope it was an OEM sensor - in the past few years it seems that aftermarket parts for our cars has taken a nosedive in reliability/quality.
I'd almost be inclined to wonder if that same sensor is the culprit? Failing under high-underhood temps?
If it was aftermarket that was installed, I'd be suspicious of that same one still being faulty, personally.
But again, depending on the symptoms, may point definitely to the output speed sensor (speedo needle 'bouncing' or falling to zero, etc).
I do hope it's another inexpensive fix.
2001 Intrepid ES
08-02-2012, 09:18 PM
Akron |
141 |
I'm not sure what kind of sensor they installed, but it is NOT the same sensor, unless it needs BOTH of them. The thing with the spedometer is NOT a symptom of an input speed sensor. When I told him people were telling me the OUTPUT speed sensor was to blame, he asked if the spedometer sometimes read zero, The INPUT speed sensor, which they replaced last time, does not cause spedometer problems.
I just do not have any peace about replacing my car until spring.
It was $20 for the sensor, $20 for the labor, and tax.
08-07-2012, 06:28 AM
s/e ma |
11,900 |
Hopefully happy trails for a while now.
