08-11-2012, 11:44 PM
socal |
Model: chrysler concorde |
Color: blue |
372 |
Stroker #3
i suppose this is where it all starts at.
i peeked into the bottom of my block to see the damage, looks bad, but should be viable for a stroker.
i'm going to be going slow on this one
its 115 during the day and dips down to a low 100 at night.. another reason progress is going to be slow.
i started the tear down, checking out what i got to work with.
i found the bearing in the oil pan, i was expecting that though.
pics to start the party with
looks like the thrust bearing.
bottom
not too beat.
my other "ride" in the background!!! MOPAR or NO CAR!!! haha living it.
im still re-reading th other 2 threads to decide if im grinding block or end-caps.
08-12-2012, 09:12 AM
14,170 |
08-12-2012, 02:59 PM
Omaha, NE |
401 |
EH nothing a little JB Weld can't fix!
08-12-2012, 05:21 PM
Maine USA |
Color: Toxic Orange Pearl |
119 |
Well, you know what the bottom end looks like now. Kinda curious why the bearings decided to just give up. Judging by how brown she is in there, I'd say poor lucubration and maintenance.
Overkill. Just use some super glue.
08-13-2012, 07:12 AM
Midlothian, VA |
Model: Intrepid Motorsport |
Color: Silver & Black |
2,437 |
 There is always room for one more in the club!
09-05-2012, 04:52 PM
socal |
Color: blue |
372 |
it never drops below 85 degrees and its been thunderstorming lately... so 100F with 90% humidity... not conductive for wrenching...IMHO.
i still love the desert.
anyways, the motor is in parts on my table.
heads off
i didnt have the special tool for the oil pump pully. so i just left it on the crank and pulled it whole. ill get it later.
the journals almost look good.....
hey please tell me i can machine this out.....
Originally Posted by dmondeac
I had the block squared, which means decked and line honed to true everything up, the block was hone to .001 oversize to be better able to run nitrous. There are no off the shelf oversized piston so, I am using stock 4.0L pistons which are the exact same size as the 3.5L pistons just the rod length and wrist pin location is different. The mains are stock 3.5L size with the 4.0L crank mains reduced by almost 0.200 to fit the 3.5L mains.
(quoted from your 4.0 thread http://www.dodgeintrepid.net/showthr...=180952&page=3 )
can i bore the journals and use 4.0 bearings?
i swear if it wernt for bad luck id have none.
09-05-2012, 06:14 PM
socal |
Color: blue |
372 |
thanks for the PM with good news dmondeac.
so unlike dmondeac and dodgebob my 4.0 crank will be stock.
now the journals on the block will be line bored.
next step get that crank here.
get the block, heads, rockers to the machine shop
for hot tanking, trueing, milling etc.
i was looking at the exhaust headers from the nitro. think they allow more aiflow then G1 headers?
http://www.moparpartsamerica.com/par...HAUST%20SYSTEM
lol the right is 100$ and the left is 39 $
09-05-2012, 08:37 PM
Indiana |
Model: Intrepid r/t |
Color: 2 tone black and red |
202 |
ouch....well good luck man! If nothing else u can make a sweet coffee table outta it!!! j/k
09-06-2012, 07:00 AM
Panama City, FL |
Model: Intrepid R/T |
1,203 |
Yep, looks like line boring is the best way to go for your block. Thats pretty nasty for someone to run it to the point they ground thru the main and into the block webbing. Yikes!
09-06-2012, 08:49 AM
Sent from my SCH-S720C using AutoGuide.Com Free App
09-06-2012, 09:25 AM
Farticcus of Plenticcus |
39.188626,-84.661524 |
Color: PDR |
15,731 |
Originally Posted by zerokool
They look an awful lot like the stock LX manifolds, which will not fit our cars whatsoever.
1G FTW!!
09-06-2012, 02:52 PM
I may have an extra set of manifolds...
10-05-2012, 10:17 PM
Panama City, FL |
1,203 |
So whats the word? Any building going on here?
10-05-2012, 11:06 PM
Lancaster / Palmdale |
315 |
Your car
10-05-2012, 11:53 PM
Panama City, FL |
1,203 |
Originally Posted by el_charal
Your car
That's the desired effect! It works, it works! and it has a 4.0 stroker, meaner than a junkyard dog!
