09-30-2012, 02:30 AM
25,669 |
Shell Rotella
So how many people use the Shell Rotella oil? And what type and weight are you using?
09-30-2012, 08:54 AM
14,170 |
I use it for my motorcycle... that's all though.
09-30-2012, 09:38 AM
Lowell, IN |
Model: Eagle Vision TSI PHP |
Color: Char-Gold Satin Met |
1,629 |
I use 15w40 in the GTX with a zinc additive, not in any other cars.
09-30-2012, 10:10 AM
get off my lawn |
Smyrna , Tn |
Color: PS2 |
13,917 |
im sorry,, I dont own a diesel
09-30-2012, 02:04 PM
May : Back in the office in Indianapolis |
Model: Intrepid(Project 14) |
Color: Light Almond Pearl |
822 |
After reading Peva's write up, I switched to Rotella T-6, 5w -40w..
09-30-2012, 08:33 PM
12,410 |
I did this on my intrepid for one oil change. I got a slightly longer tick at startup than I was use to so I switched back.
09-30-2012, 08:43 PM
Lowell, IN |
1,629 |
I didn't see it, anyone have a link?
09-30-2012, 08:47 PM
822 |
10-01-2012, 08:46 AM
Lowell, IN |
1,629 |
Thanks
Rotella is a good oil, I use the none synthetic version for my flat lifters in the GTX, I could use synthetic as well but it's not worth it to me, I change the oil twice a year on this car and only put 3000-4000 miles on it.
On the drivers I still use what's on sale and change it at 3000, it's working for me on all my high mileage cars and I can do an oil change for around $16-$18
11-16-2012, 01:19 PM
Just to chime in with my experience... I'm using Shell Rotella T6 5w40 currently, 1 gallon, with two quarts Rotella 15w40 (6 quarts were needed, and I didn't want to buy a second full gallon of t6)...
And now for short runs, my car is fine, makes no noise... but after a decent drive (20 miles or so?) it begins to hammer a bit - really quiet, but you can hear it at idle...
I'll be dropping the oil here soon in favor for something else (likely Valvoline Dino, 5w30) and a filter change - I think I'll take some of the oil from the filter and send it to Blackstone.
11-16-2012, 11:54 PM
3,513 |
Honestly the only way to tell rather or not your oil, or oil additives are doing anything is with solid proof. Using any oil analyst company would help. Say for instance I use Mobil Clean5k 10w30. I use to do 4 qts of it with one qt of lucas oil stuff. Blackstone noted my wear was great, and my viscosity was little high due to the lucas. I also noticed that molybdenum, an anti-wear agent in oil was high. So for 4 oil changes I stopped using lucas. The last report showed a jump in bearing wear, nothing critical but also showed my moly levels almost flatline compared to the old readings. So I put lucas back in and once this oil run is done back to blackstone to see if the lucas is indeed helping with bearing wear.
11-17-2012, 03:42 PM
Blackstone kit is on the way - but I'm going to drop my oil now and reserve a helping of it to send in when my kit arrives.
11-28-2012, 09:59 PM
25,669 |
I think I'll pass on the "Craptella" oil. Thanks for the responses though.
11-28-2012, 10:07 PM
Come at me Bro! |
Lizard Lick, NC |
Model: Dodge Intrepid |
Color: Go-mango |
28,078 |
Rotella is not really meant for gasoline engines--although many still use it for gas burners. It is used very commonly in light to heavy duty diesels, and is formulated for diesels. It is the only oil we stock at work (heavy duty truck shop)....it is most definitely not "craptella" IMO. Some of the insanely complicated V8 Ford diesels use a lighter weight than 15w40...to keep them from exploding...LOL...
I used it in both dodge Rams, one for 100K miles, the other for 200+K miles, both engines were clean as a whistle inside. It is excellent at keeping the sulphur and soot deposits from the diesel fuel from sticking to the internals. The old red 93 dodge, now with 390K miles, is still kicking strong on Rotella, we've ran it since 1997 when we bought the truck---which is now my dad's.
This is under the valve cover on my white 99 Ram, after ~50K of Rotella...this is with about 240K on the engine:
As far as gas burners, I have always been a firm believer in Mobil 1 5w30, with a Mopar oil filter, used it since zero miles on my intrepid's engine, and it has had great results. No abnormal wear on oil analysis, and the engine has remained clean enough to eat off of inside. Like Devan says, go off of proven results.
The only gas burner I ran Rotella in was my old 85 F150, with the straight 6, it quieted it down a bit, raised the oil pressure.
Member of The Twin Magnums of Di.net
 Proud sponsor of Just Junk It, LLC.
11-28-2012, 10:18 PM
I got my Blackstone kit, I'll mail it in this weekend.
