10-15-2012, 09:05 PM
washington |
Model: concorde |
Color: cinnamon |
5 |
what cluster years work w/99 concorde
can anyone tell me what clusters work with 99 Concorde? Ive read a number of post but no hard answer .
10-16-2012, 06:46 PM
Cleveland, Ohio |
Color: Platinum |
1,636 |
better question is "What cluster do you want? and How do you make it work?"
10-17-2012, 06:48 PM
washington |
Model: concorde |
Color: cinnamon |
5 |
Ok
99 cluster w/chrome bezels, i assume are direct fit work w/no compatibility issues?
00-04 cluster w/chrome bezels, direct fit or what are there compatibility issues?
00-04 fancy white faced, (from the limited model) direct fit or what are there compatibility issues?
and is the mileage stored in ecu or cluster or dose it vary one the cluster year?
10-17-2012, 06:51 PM
Uber Goober |
26,094 |
10-17-2012, 07:46 PM
washington |
Model: concorde |
Color: cinnamon |
5 |
99-04 all clusters are direct fit w/the Concorde non auto stick
10-17-2012, 08:18 PM
10,370 |
LHS white with chrome rings cluster will be non-A/S (as opposed to 300M, all of which are A/S). That's what i put in my '99 Concorde LX (before I converted it to A/S, so now it has 300M cluster). Something else that really looks nice is the black cluster with chome rings from the later Concordes (not the Limited) - I have that in my '98 Concorde LXi.
10-17-2012, 08:25 PM
Uber Goober |
26,094 |
Not true. If you're trying to put an Autostick cluster in a car without...you will run into issues. The only true part about your statement is all 2nd gen LH clusters will "Physically fit"...that doesn't mean they will work electrically or functionally.
10-17-2012, 08:54 PM
washington |
Model: concorde |
Color: cinnamon |
5 |
I give thanks to everybody for their input and i think others also, so they don't have to go thru the trial and error process. so wich one of the clusters will be a R&R with no issues. (id perfer white but the chrome wiil do. their both better than stock) if u can give some #'s of some sort to help identify the correct one. ( such as model years or other )
10-18-2012, 01:35 AM
10,370 |
I don't know if anyone knows all combinations by part number to be able to answer that thoroughly. You have to watch about certain options like TRAC and ABS to match beteween your car and the donor car, otherwise you can get constant warning lights (which you could tape over I guess). There have been absolutely no problems with the combinations I mentioned.
...(id perfer white but the chrome wiil do...
I don't understand. Did you mean to type something different there?
10-18-2012, 07:21 PM
washington |
Model: concorde |
Color: cinnamon |
5 |
i mean the fancy white gauge or the black W/chrome rings gauge. I'd would prefer the white fancy though.
so it sound like if i stick to a 99-02 cluster or the closest year as possible I'll have the least amount of issues? sorry to seem ignorant just don't want to pay for a item that wont work.
oh yeah, how about the how the mileage is stored is it the ecu or the gauge cluster or dose that vary on year and cluster
10-18-2012, 08:03 PM
Cleveland, Ohio |
Color: Platinum |
1,636 |
Your best bet is a Cluster out of a LHS (like Bill mentioned above) , which I have one from a 2000 (should work with no issues) if you are interested send me a PM. I also have the Black with Chrome from a later Cord if you wan that.
10-18-2012, 08:16 PM
10,370 |
...how about the how the mileage is stored is it the ecu or the gauge cluster or dose that vary on year and cluster
Mileage is stored in the BCM and sent to the cluster - same for all years.
