11-12-2012, 11:25 AM
Florida |
23 |
Problems starting car this morning
This morning (45 degrees, 100% humidity), my car refused to start for the longest time. It'd crank but not "catch" strong enough to actually start. It'd half-sputter a few times, but refused to actually start. I was parked slightly uphill, so I coasted the vehicle and turned to make it level, and tried a few more times. It finally caught and ran a little rough. I was late to work as it was, so drove a different car into work.
Looking at the tailpipes, I saw white exhaust that trailed out by a couple feet. Not sure how unusual this is for the vehicle and weather conditions. Didn't let the engine get up to temperature to see if it went away. My other vehicle had a little white smoke but not nearly as thick.
1) Could this be water in the gas? I will try some HEET tonight to see if that fixes the problem.
2) Engine has not overheated, so should not be a cracked head.
3) I looked at the coolant and oil. No signs of oil in coolant (stuck a paper towel in and came out clean) nor any signs of foamy suds in oil. Will look at oil again tonight.
4) Probably unrelated, but I am hearing a random metallic clanging in engine block. Need to have this looked at.
5) Also likely unrelated, but occasionally I'll hear a funny whine when accelerating around 3,500 rpm. Sounds like the coolant pump sheave is slipping (I think I have a small coolant leak that splatters coolant on my fan belt causing it to get more slick than normal.) Haven't had this problem in a few weeks.
Appreciate any input you may have.
11-12-2012, 12:42 PM
10,378 |
It may be that the fuel rail is emptying when it sits due to a leaking fuel injector leaking fuel into a cylinder, or the fuel pump check valve or pressure regulator leaking back to the tank.
If that's the problem, you could get it to start quicker by cycling the key from off to run 2 or 3 times, waiting at each position for 3 seconds or so. That runs the fuel pump for a second or two each time it goes to "Run" to refill and presurize the rail. Then, once it starts, it would sputter for a few seconds due to air in the fuel rail bubbling thru, and then finally smooth out and run fine until the next start after sitting for a while.
Originally Posted by bigtrees
...Sounds like the coolant pump sheave is slipping (I think I have a small coolant leak that splatters coolant on my fan belt causing it to get more slick than normal.)...
FYI, the water pump is run by the timing belt. But it could be getting wet as you said.
Sheave, huh? The only time I've heard that term (instead of "pulley") is when I worked with cranes - sheaves are the pulleys that the steel cables sit in. I'm curious where you picked up the word. Maybe it's more commonly used than "pulley" in some countries?
'98 LXi - Later Concorde gages (black w/ chrome rings)/'99 LX - LHS gages (white) - HIR bulbs
11-12-2012, 01:17 PM
Florida |
23 |
Is it possible for any of the fuel-related issues to cause the random metallic clanging noise in the engine? I read that high pressure fuel pump issues on trucks can create metallic popping pop corn sounds in engine. Does the 300m have any high pressure fuel pumps in the engine compartment?
I have smelled gas around the vehicle a few times, and this morning smelled a lot of gas as I was trying to start it.
As far as sheave, it's something I learned in engineering school. A professor and textbook were very firm about calling them sheaves and not pulleys. I think he thought pulley sounded more shade tree mechanic while sheave sounded more professional. I think they're interchangeable.
11-12-2012, 01:39 PM
I read the following as meaning "A Pulley is a machine (simple machine), where a Sheave is a part of that machine."
pulley n : a simple machine consisting of a wheel with a groove in which a rope can run to change the direction or point of application of a force applied to the rope [syn: pulley-block, block
Pulley \Pul"ley\, b. t. To raise or lift by means of a pulley. [R.] --Howell.
Pulley \Pul"ley\, n.; pl. Pulleys. [F. poulie, perhaps of Teutonic origin (cf. Poll, v. t.); but cf. OE. poleine, polive, pulley, LL. polanus, and F. poulain, properly, a colt, fr. L. pullus young animal, foal (cf. Pullet, Foal). For the change of sense, cf. F. poutre beam, originally, a filly, and E. easel.] (Mach.) A wheel with a broad rim, or grooved rim, for transmitting power from, or imparting power to, the different parts of machinery, or for changing the direction of motion, by means of a belt, cord, rope, or chain. Note: The pulley, as one of the mechanical powers, consists, in its simplest form, of a grooved wheel, called a sheave, turning within a movable frame or block, by means of a cord or rope attached at one end to a fixed point. The force, acting on the free end of the rope, is thus doubled, but can move the load through only half the space traversed by itself. The rope may also pass over a sheave in another block that is fixed. The end of the rope may be fastened to the movable block, instead of a fixed point, with an additional gain of power, and using either one or two sheaves in the fixed block. Other sheaves may be added, and the power multiplied accordingly. Such an apparatus is called by workmen a block and tackle, or a fall and tackle. See Block. A single fixed pulley gives no increase of power, but serves simply for changing the direction of motion. Band pulley, or Belt pulley, a pulley with a broad face for transmitting power between revolving shafts by means of a belt, or for guiding a belt.
Cone pulley. See Cone pulley. Conical pulley, one of a pair of belt pulleys, each in the shape of a truncated cone, for varying velocities.
Fast pulley, a pulley firmly attached upon a shaft.
Loose pulley, a pulley loose on a shaft, to interrupt the transmission of motion in machinery. See Fast and loose pulleys, under Fast.
Parting pulley, a belt pulley made in semicircular halves, which can be bolted together, to facilitate application to, or removal from, a shaft.
Pulley block. Same as Block, n. 6.
Pulley stile (Arch.), the upright of the window frame into which a pulley is fixed and along which the sash slides. Split pulley, a parting pulley.
Sheave \Sheave\, n. [Akin to OD. schijve orb, disk, wheel, D. schiff, G. scheibe, Icel. sk[=i]fa a shaving, slice; cf. Gr. ??? a staff. Cf. Shift, v., Shive.] A wheel having a groove in the rim for a rope to work in, and set in a block, mast, or the like; the wheel of a pulley. Sheave hole, a channel cut in a mast, yard, rail, or other timber, in which to fix a sheave.
Sheave \Sheave\, v. t. [See Sheaf of straw.] To gather and bind into a sheaf or sheaves; hence, to collect. --Ashmole.
So, I think you can use them interchangeably - but like BigTrees says, some times someone really feels strongly... I had a teacher that say we didn't go to Gym class, or hold it in the Gym - it is called Physical Education, and it is held in the Gymnasium... He kept wanting us to tell him why we were going to Jim's while we were at school, and how we'd have Physical Education in Jim.
11-12-2012, 01:48 PM
1,438 |
Sheave sounds like shave and always reminds me of something that shears off. I always have to think twice when I hear that word.
I gather you have a 300m Special since you noted the tailpipe(s). The fuel pump on all LH cars is in the fuel tank but, runs rail pressure down the body and up to the engine at roughly 60psi. There was a TSB way back for the early LH cars having a popping sound in the tubes running under the body but, none of the later models had that issue and none of the second generation LH cars IIRC.
11-12-2012, 02:28 PM
Florida |
23 |
Random metallic clanking / popping
Are there other possible causes not fuel related for a random metallic clanking? It sounds like it is just below the air plenum in the engine block.
Is there any reason to not drive the vehicle until this is fixed? I don't want to do any damage, but need to drive.
Finally, how hard is it to swap out fuel injectors? I have swapped out wheel bearings and done a lot of troubleshooting on my vehicles, so I'm handy, but not skilled enough to overhaul an engine or transmission (as examples).
11-12-2012, 02:38 PM
1,438 |
If you have a lift handy that would be a big help. Any close buddies working as a mechanic? I think you should be at least concerned about clanking and definitely get it checked out before it gets worse. Can you explain the symptoms associated with the noise? Like only idling or at say 1 -2 upshifts etc.
My first guess would be exhaust. there are two brackets at the base of the transmission mount which is also not far from the back of the engine which frequently fracture and are noisy on some cars.
11-12-2012, 04:15 PM
Sangudo, AB |
Model: LHS |
Color: Dark Slate Pearl |
331 |
in heating, when "sheave" was used, it was more to the driven pulley, like that on a blower. pulley was on the motor.
but that was more in written words. (manuals, parts books)
i don't think it's as much country as profession and generation.
although, when i hear sheave, i think more bundles of grain stalks.
11-12-2012, 11:13 PM
10,378 |
...I have smelled gas around the vehicle a few times, and this morning smelled a lot of gas as I was trying to start it...
Hmm - that is more evidence of possible leaking injector. When you have a leaky injector and the fuel rail empties into a cylinder, then when you try to start it, there is raw fuel in that one cylinder, and you will smell that coming out the exhaust. So that one cylinder is seriously flooded, while the other 5 are getting no fuel at all - hence the no-start (until the key is cycled to run the fuel pump enough to fill and pressurize the rail).
If the emptying of the rail was fuel pump related (i.e., leaking check valve or pressure regulator - all located in the fuel tank), you would not get the raw fuel smell when you tried to start it - in fact that's how you tell if it's leaking injector(s) vs. fuel pump leakdown that's emptying the rail.
11-12-2012, 11:32 PM
Wisconsin |
190 |
I would start by checking your fuel pressure and then doing a five min leak test! Fuel pressure should be 44-54 psi to do the leak test turn the key on and let the pressure up to spec. then shut off the key and let it sit for 5 min. the pressure should not drop below 30 psi! and if you haven't already I would get a Chilton book for your car! If the car is not starting you will get the strong fuel smell wile trying to start it and for several min. after it starts! This also may not be a fuel problem at all it could be the IAC!
Reason: Adding more
11-12-2012, 11:50 PM
NEVER! For shame! Haynes beats chilton hands down, but a Factory Service Manual is the only way to go... the ONLY way to go. I'll have to find the links - they are available readily in specific places.
12-20-2012, 07:24 PM
BC |
Color: pearl slate PAW |
211 |
Neither Haynes or Chilton (unless you get a freebie) FSM is the only way to go. I got mine (PDF file) from a link at this site but I can't recall the specifics.
