11-21-2012, 11:01 AM
#46
11-21-2012, 08:56 PM
#47
usa |
Year: 1993 |
Model: concorde |
Color: light driftwood |
111 |
SSD = Solid State Drive
11-21-2012, 09:15 PM
#48
1,404 |
Originally Posted by cdmccul
I'll have to check that out. But, yeah on the DILYSI. Good detective work!
11-21-2012, 10:12 PM
#49
1,749 |
PANIC: People Are Not In Control  Canst forget that one!
11-21-2012, 10:15 PM
#50
1,749 |
11-21-2012, 11:39 PM
#51
Updated - Good catch on SSD
11-22-2012, 11:23 AM
#52
1,404 |
SKREEM, Sentry Key Remote Entry Module. (See SKIM and WCM, WIN). WIreless Control Module and Wireless Ignition Node on later cars/trucks.
11-22-2012, 12:21 PM
#53
Will update next time I'm on a PC.
11-22-2012, 01:00 PM
#54
1,404 |
I've got a TON of service manuals. If you had an inkling to separate these into car-related and Other stuff, I could probably dig out a bunch more.
11-23-2012, 12:28 PM
#55
I was more trying to go for acronyms that we might find here, from chat related (LOL) to conversations (IIRC) to cars (BCM) to computers and tech (HDMI)...
Although fun, I'm not really trying to re-invent the acronym websites... But yes, if it is something we're likely to discuss on the board, sure, Let me know.
11-23-2012, 12:30 PM
#56
So, what is WCM and WIN, since you posted it?
11-23-2012, 12:31 PM
#57
213 Total
1G - First Generation (1993-1997) (See 2G)
2G - Second Generation (1998-2004) (See 1G)
4x4 - four wheel drive (See AWD) (See RWD) (See FWD)
A/S - AutoStick (also AS)
ABS - Acrylonitrile Butadiene Styrene (black plastic, often used in piping and other automotive plastic needs) (See PVC)
ABS - Automatic Braking System (See TCS) (See Trac) (See CAB)
AC - Air Conditioning
AC - Alternating current (household power) (See DC)
ACC - AC Compressor Clutch
ACM - Airbag Control Module
ACRONYM - Abbreviated Coded Rendition Of Name Yielding Meaning
ADI - If you rock a white belt and have really loud Thubz
ASD - Automatic Shut Down (Relay)
AT - Automatic Transmission (See MT)
ATC - Automatic Temperature Control (See MTC)
ATX - Advanced Technology eXtended (motherboard form factor)
ATX - Automatic Transaxle
AWD - All Wheel Drive (See RWD) (See FWD) (See 4x4)
B+ - Battery Voltage
BBL - Be Back Later
BBS - Bulletin Board System
BCM - Body Control Module
BFH - Big F**kin Hammer
BFP - Big F**kin Pliers
BFS - Big F**kin Screwdriver
BPEGR - BackPressure Exhaust Gas Recirculation
BRB - Be Right Back
BSOD - Blue Screen Of Death (See Dick run? Run Dick, run!)
BTDT - Been There Done That
BTW - Blue Tipped Wrench
BTW - By The Way
Byte - eight bits used to define a single character, with each bit set to 0 or 1, thus providing 256 unique single characters (See Kb)
CAB - Controller Antilock Brake/ (See ABS)
CAI - Cold Air Intake
CCD Bus - Chrysler Collision Detection Bus (Serial Data Bus)
CD - Compact Disc (See DVD)
CDMcCull - Cean Daniel McCull... (first initial, middle initial, and first six letters of last name)
CEL - Check Engine Light (See DTC) (See MIL)
CHMSL - Center High Mounted Stop Lamp
CKP - Crankshaft Position Sensor (See CMP)
CKT - Circuit
CMP - Camshaft Position Sensor (See CKP)
COP - Coil On Plug (See DIS)
CTRL - Control
CV - Constant Velocity (CV Shaft)
DC - Daimler Chrysler
DC - Direct current (battery power) (See AC)
DI - DodgeIntrepid(.net)
DILLIGAF - Does It Look Like I Give A F**K
DILYSI - Drive It Like You Stole It
DIS - Distributor-less Ignition System or Direct Ignition System (See COP)
DLC - Data Link Connector (Formerly called "Engine Diagnostic Connector") (See STI)
DOHC - Dual Over Head Cam (See OHC) (See SOHC) (See OHV)
DPDT - Doube Pole Double Throw (See SPDT)
DRB(I, II, III, etc) - Diagnostic Readout Box (Chrysler Scan Tool)
DRL - Daytime Running Lights
DS - Dark Slate
DTC - Diagnostic Trouble Code*(See CEL) (See MIL)
DVD - Digital Versatile Disc (See CD)
EATX - Electronic Automatic TransaXle
ECM - Engine Control Module (See ECU) (See PCM)
ECT - Engine Coolant Temperature
ECU - Engine Control Unit (See ECM) (See PCM)
EEPROM - Electronically Eraseable Programable Read Only Memory
EET - Electronic EGR Transducer
EGR - Exhaust Gas Re-circulation
EI - Electronic Ignition
EMCC - Electronically Modulated Converter Clutch
EMF - ElectroMagnetic Frequency
ETBE - Ethyl Tertiary Butyl Ether
EVAP - EVAPorative emission controls (fuel vapor)
EVIC - Electronic Vehicle Information Center (See OTIS)
FDD - Floppy Disk Drive (See HDD) (See SSD)
FF - Flexible Fuel
FFDP - Five Finger Death Punch (See Fred) \m/*
FP - Fuel Pump
FPR - Fuel Pressure Regulator
FR - Fuel Filler Tube Restrictor
Ft. Lbs. - Foot Pounds (rotational torque) (See In. Lbs.)
FTL - For The Loss
FTMFGDW - For The Mother Fu**in' G*ddamn Win!
FTW - For The Win
FUBAR - F**ked Up Beyond All Recognition (censored)
FWD - Front Wheel Drive (See RWD) (See AWD) (See 4x4)
FWIW - For What It's Worth
FYI - For Your Information
Gb - GigaByte (a measure of memory capacity, 1024 Mb) (See Mb) (See Tb)
GEN - GENerator
GTFO - Get The F**k Out
HD - High Definition (See HDD)
HDD - Hard Disk Drive (See HD) (See FDD) (See SSD)
HDMI - High-Definition Multimedia Interface (See VGA)
HID - High Intensity Discharge
HMFWBIC - Head Mother Fugger Who Be In Charge
HO2S - Heated Oxygen Sensor
HSM - Heated Seat Module
IAC - Idle Air Control
IAT - Idle Air Temperature
IDGARA - I Don't Give A Rat's A**
IDK - I Don't Know
IIRC - If I Remember Correctly
IMHO - In My Humble Opinion
IMO - In My Opinion
IMPG - Instant Miles Per Gallon (See MPG)
In. Lbs. - Inch Pounds (rotational torque) (See Ft. Lbs.)
InHG - Inches of Mercury
IOD - Ignition Off Draw
IOW - In Other Words
ISCA - Iowa Student Computer Association
Kb - KiloByte (a measure of memory capacity, 1024 bytes) (See Byte) (See Mb)
Kg - Kilograms
Lbs - Pounds
LED - Light Emitting Diode
LH - Another website (See DI)
LH - The fine automobile family (platform, chassis) designation this website celebrates, covering Dodge Intrepid, Eagle Vision, Chrysler Concord/LHS/New Yorker/300M.
LMAO - Laughing My A** Off
LOL - Laughs Out Loud (like we ever do that!) (See ROFLMAO)
LX - The next series design spawned from the LH platform
M - Manifold vacuum
MAP - Manifold Absolute Pressure
Mb - MegaByte (a measure of memory capacity, 1024 Kb) (See Kb) (See Gb)
MFI - Multi-port Fuel Injection (See TBI) (See SFI)
MIL - Malfunction Indicator Lamp (Check Engine Light) (See CEL) (See DTC)
Mod - Moderator
Mod - Modification or customization
MPG - Miles Per Gallon (See IMPG)
MSM - Memory Seat Module
MT - Manual Transmission (See AT)
MTBE - Methyl Tertiary Butyl Ether
MTC - Manual Temperature Control (See ATC)
MTV - Manifold Tuning Valve (See SRV)
MTV - Music TeleVision (See VH1)
MVLPS - Manual Valve Lever Position Switch
NGC = Next Generation Controller (2002 + LH Vehicles)
O2S - Oxygen Sensor (Left side sensor when there are two sensors) (See O2SR)
O2SR - Oxygen Sensor, Right (See O2S)
OBD - On-Board Diagnostics
OBDII - On-Board Diagnostics, stage II
OC - Oxidation Catalyst
OEM - Original Equipment Manufacturer
OHC - Over Head Cam (See DOHC) (See SOHC) (See OHV)
OHV - Over Head Valve (See DOHC) (See SOHC) (See OHC)
ORD - OveRDrive running clutch
OSH - Oh Sh!t Handle
OTIS - Overhead Travel Information System (See EVIC)
P - Ported vacuum
PAIR - Pulse Air Injection System
PCI - Programmable Communication Interface
PCM - Power-train Control Module (See ECM) (See ECU) (See TCM)
PCV - Positive Crankcase Ventilation (See PVC)
PDC - Power Distribution Center
PEVA - Poly-Ethylene Vinyl Acetate
PEVA - Respected knowledge base and clairvoyant about when his name is posted to the site.
PIWWC - Pulse Intermittent Windshield Wiper Control
PL - Power Locks
PM - Private Message
PRDNL - Park Reverse Neutral Drive Low (shift indicator)
PS - Power Steering
PSBM - Passive Seat Belt Module
PSI - Pounds per Square Inch
PVC - Poly-Vinyl Chloride (white plastic piping)*(See ABS) (See PCV)
PW - Power Windows
RIP - Rest In Peace
RKE - Remote Keyless Entry
ROFLMAO - Rolls On Floor Laughing My A** Off (like how often does that really happen?) (See LOL)
RTFM - Read The F**kin Manual
RTV - Room Temperature Vulcanizing - AKA silicone sealant (but may not be technically silicone), gasket maker
RWD - Rear Wheel Drive (See FWD) (See AWD) (See 4x4)
S/C - Speed Control
SBEC - Single Board Engine Controller (See PCM) (See ECU) (See ECM) (See SMEC)
SFI - Sequential Fuel Injection (See TBI) (See MPFI)
SJB - Squilly's Jubilant Buttocks
SKIM - Sentry Key Immobilizer Module (See VTSS)
SKREEM, Sentry Key Remote Entry Module. (See SKIM) (See WCM) (See WIN)
SMEC - Single Module Engine Computer (See PCM) (See ECU) (See ECM) (See SBEC)
SOHC - Single Over Head Cam (See DOHC) (See OHC) (See OHV)
SPDT - Single Pole Double Throw (See DPDT)
SPK - ignition SParK controls
SRI - Service Reminder Indicator
SRS - Supplementary Restraint System (air bags)
SRV - Short Runner Valve (See MTV)
SS - Stainless Steel
SSD - Solid State Drive (See FDD) (See HDD)
SSDD - Same S*** Different Day
STFU - Shut The F**k Up
STI - Self Test Input (Data Link Connector) (See DLC)
T - Throttle-body vacuum
TAC - Thermostatic Air Cleaner
Tb - TeraByte (a measure of memory capacty, 1025 Gb) (See Gb)
TB - Timing Belt
TBI - Throttle Body Injection (See SFI) (See MPFI)
TC - Torque Converter
TC - Traction Control
TCC - Torque Converter Clutch
TCM - Transmission Control Module (See PCM)
TCS - Traction Control System (See ABS) (See Trac)
TPS - Throttle Position Sensor (or TPS report, which needs to have a cover sheet)
Trac - Traction Control (See ABS) (See TCS)
TTT - To The Top (bump)
TWC - Three Way Catalytic converter
VAC - Vacuum
VECI - Vehicle Emissions Control Information (label)
VGA - Video Graphics Array (See HDMI)
VH1 - Video Hits 1 (See MTV)
VSS - Vehicle Speed Sensor
VTSS - Vehicle Theft / Security System (See SKIM)
WCM -
WIN -
WOT - Wide Open Throttle
WP - Water Pump*
WTF - What The Fu** (censored) (See WTH)
WTH - What The Hell (See WTF)
YMMV - Your Mileage May Vary
11-23-2012, 03:15 PM
#58
Minnesota |
79 |
WCM - Wireless Control Module
WIN - Wireless Ignition Module
and a couple more off the top of my head
TIPM - Totally Intergrated Power Module
CTM - Central Timer Module
R/T - Road & Track
SRT - Street & Racing Technology
11-23-2012, 03:25 PM
#59
Minnesota |
79 |
also missing VIN - Vehicle Identification Number
11-23-2012, 03:32 PM
#60
VERY GOOD! I have updated and added them now.
Total, 218
BBL - Be Back Later
BRB - Be Right Back
BTW - By The Way
CKT - Circuit
CTRL - Control
DS - Dark Slate
FF - Flexible Fuel
FP - Fuel Pump
FTL - For The Loss
FTW - For The Win
GEN - GENerator
IDK - I Don't Know
IMO - In My Opinion
Kg - Kilograms
Lbs - Pounds
M - Manifold vacuum
Mod - Moderator
P - Ported vacuum
PL - Power Locks
PS - Power Steering
PW - Power Windows
R/T - Road & Track
RIP - Rest In Peace
S/C - Speed Control
TB - Timing Belt
VAC - Vacuum
WIN - Wireless Integration Node
WP - Water Pump*
