1995 Eagle Vision
Hi all.
I just acquired a1995 Eagle Vision with a 3.3. The only thing that was supposed to be wrong with it was an over charging issue. Well was I fooled!
Got it home and started it then it died. Will not restart, No Spark.
I started to do a Key Dance to check for codes and nothing. When I turn the ignition on, all the lights light in the dash except for the check engine light. Thinking it may be a bad bulb, I pulled the dash and ohms checked the bulb out of the dash. All is good.Reinstalled, still no check engine light with just the ignition on. It did flash real quick once. Can't do a key dance LOL.
Ideas?
Jim
