found some new headlights in pull & pay(new to me, aftermarket ones tyco)
just wanted to give idea on what someone can do if having issue like i did
1. screws were spinning as plastic cracked insert was spinning at bottom
2. first tried using a dremel with diamond wheels then drill bit to cut off headlights.
3. went to my brother's place he was an auto mechanic has just about every thing
4. used air powered hand drill with rotozip bit which made my life much easier to cut off composite headlights (remove turn signals for access on the one side)
5. then just grabbing bottom section with needlenose visegrips and taking out screws
6. put new ones in using antiseize on threads with brighter bulbs installed also
