08-10-2012, 04:22 PM
Morrisville NC |
Model: Intrepid R/T |
Color: PS2 Silver |
17 |
01 Intrepid Double Din in dash GPS pics
I just finished installing a double din gps stereo in dash. Here are some pics.
It took about 3 days from start to finish.
David
08-10-2012, 04:45 PM
Permanently Banned |
35 |
David
Nice job man
08-10-2012, 05:24 PM
Canuckistanian Resident |
Saskatchewan Canada |
Color: Red? |
3,688 |
I'm not overly a fan of the shiny black paint on it (I'm not a fan of 'shiny' interiors tho) but it looks to be A grade for construction!! Looks awesome!! Good job!
08-10-2012, 06:49 PM
Morrisville NC |
Color: PS2 Silver |
17 |
Gps
Its really flat black. It only looks that way because I coated the entire dash with some furniture polish. Here is what it really looks like. I too do not like the gloss look. The cover panel was rather easy to make.
Thanks for the compliments.
08-10-2012, 07:23 PM
Color: Red? |
3,688 |
That looks really really sharp!!
08-10-2012, 10:39 PM
14,188 |
very nice!
01-19-2013, 06:55 PM
nc |
Model: intrepid |
Color: forest green |
1 |
what did u do cut the mounts? mind sharing ur steps?
02-11-2013, 01:45 PM
Omaha, NE |
402 |
Would like to know how you managed to mount the double din in there...
02-12-2013, 09:20 AM
Morrisville NC |
Color: PS2 Silver |
17 |
I had to "remove" a cross brace inside. I also made a metal brace that the unit mounts to and mounts to the dash opening. Once that was in place, I remolded the cover piece and gave the outside a similar texture as the original. The heat/AC controls mounts to the cover just lie the original, just lower down the dash. The tolerances are so tight that I am reluctant to remove the cover and radio to take pictures.
02-12-2013, 09:35 AM
Morrisville NC |
Color: PS2 Silver |
17 |
02-13-2013, 03:44 AM
USA |
320 |
Looks good!
I've been playing with ideas of moving my MTC/ATC and installing a touch-screen deck in mine as well.
Did you do much cutting and modification to the console portion of the dash construction internally?
02-13-2013, 09:44 AM
Morrisville NC |
Color: PS2 Silver |
17 |
I did absolutely no mods to the center console portion at all. I only removed one cross support that is above the original radio (I think). I also had to "trim back" a couple cover mounting tabs because the heat/ac is a bit wide. I probably would not have had to do that if i had mounted the controls a bit higher. But I put the heat/ac controls at the bottom edge of the CD player hole on the cover. I may at some point try to move the heat/ac controls up a bit, but I like it just fine having the nav unit at the center of attention rather than the heat/ac controls. As far as the cover goes, That took me 3 days to complete and the tolerances for radio position is so freakin tight that when i removed the radio and reinstalled it, I was off slightly and was a lot of trouble to get lined back up.
02-18-2013, 12:56 AM
USA |
Model: Chrysler Concorde |
Color: Bright White |
5 |
I like how you have the heat and air controls lowered down. Looks great
02-21-2013, 11:34 AM
Leave Nothing Stock |
Blacksburg, VA |
Model: Intrepid SE |
202 |
Great Job!!
