Originally Posted by R/TsRock
...Also thought I'd mention that the dealer asked if I fired the car up with 1 of the coils off...Could that affect the PCM enough to kill it? (I did but can not see that causing a PCM failure?)
I have done it to 2 of my other cars which also have coils...no issues ever. Thoughts there?
If you mean that the coils were not on the plugs but were still wired up to the harness (primary) - that could damage the coils by spinning the engine with ignition on. I don't know about damaging the PCM if the coil was totally disconnected - as a circuit designer, I don't know why that would be the case, but maybe so.
When connected to a spark plug, the coil output voltage will be limited by the initial ionization voltage of the spark plug gap (20k-30k volts). The coil's insulation is designed to handle that voltage. If it is not connected to the plug, it is able to go to voltages well above what its insulation can handle (60-80-100k volts). The insulation will arc over (surface arc) or punch thru (literally burn thru a little hole), and the surface of the arcover or punch-thru hole will carbonize. That carbonized track (carbonized insulation material) is conductive. The coil is ruined when that happens because now it has an easier path to ground than thru the spark plug gap.
