06-20-2010, 11:18 PM
#1
Hamilton, ON, CA |
Year: 199x |
Model: Intrepid 3.5L's |
Color: Radiant Red/Chargold |
433 |
Low idle when hot - driving me bananas!
Driving me  !! I replaced the valve cover gaskets today, so I replaced the plugs, wires and swapped out the IAC with another known working one.. I still have a low idle issue when the engine is hot.
In Park/Neutral is idles at 650rpm and in gear it idles at 500, shaking and growing. I cleaned the throttle bodies and now I just don't know what to check. There are no fault codes. Any known issues for first gen 3.5s?
06-21-2010, 12:39 AM
#2
long island |
Year: 1995 |
Model: corde |
Color: spruce |
1,701 |
check pcv valve system also check air filter.Also the throttle position sensor could be dirty.There could also be a vacuum leak
06-21-2010, 10:06 AM
#3
Hamilton, ON, CA |
Year: 199x |
433 |
Air filter is good. I don't think there are any vacuum leaks as I just put all the vacuum lines back and the fuel rail o-ring recall was just done, so I know all the seals and gaskets are new from the plenum upwards. I'll recheck. PCV hoses are new, but I'll check the rest. TPS was a thought - I'll clean it or swap it out.
Thanks for the ideas. I think some of which I take for granted are fine. ;) I'll check it out.
06-21-2010, 04:44 PM
#4
Maryland |
Year: 1997 |
Color: Stone White |
1,341 |
egr valve?
06-21-2010, 06:18 PM
#5
Intrepid Fan |
Kenosha, Wisconsin |
Year: 1996 |
Color: Candy Apple Red |
176 |
Don't forget to check the lower intake gasket. Common problem,
06-22-2010, 09:31 AM
#6
Hamilton, ON, CA |
Year: 199x |
433 |
Originally Posted by mass04
egr valve?
The EGR valve itself works all right. I did have to replace the transducer solenoid though not too long ago as it was leaving fault codes. This issue with low idle has existed since I bought the car and there are no current fault codes.
06-22-2010, 09:32 AM
#7
Hamilton, ON, CA |
Year: 199x |
433 |
Could it be though? Usually an intake leak causes a fluctuation in rpm, not a steady low idle. I can check it anyway just to be sure.
06-23-2010, 12:24 AM
#8
georgia |
Year: 2004 |
Model: Intrepid Police Pkg |
Color: Midnight blue pearl |
5,622 |
the intake gasket would cause a high-idle IIRC
06-23-2010, 12:54 PM
#9
Maryland |
Year: 1997 |
1,341 |
Not necessarily, the IAC will continuously adjust for it making it fluctuate
10-03-2010, 03:36 PM
#10
Hamilton, ON, CA |
Year: 199x |
433 |
It's pretty much fixed.
I couldn't find any reason for the low idle when hot, other than the throttle body adjustments. I noticed on the throttle bodies, someone has removed the plugs for the adjustment, so I figure some moron along the way was fudging around with it. So it's adjusted and idles at about 575rpm in gear now, which is a huge improvement. Next spring I will refine it more. The car is parked now for the winter.
10-03-2010, 11:36 PM
#11
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
Parked for the winter?
