01-19-2011, 07:33 PM
#1
Panama City, FL |
Model: Intrepid R/T |
Color: Stone White |
1,203 |
Another 4.0 stroker is born!
__________________
"It's finally built the way Dodge should have built it."
01-19-2011, 08:06 PM
#2
Midlothian, VA |
Model: Intrepid Motorsport |
Color: Silver & Black |
2,439 |
Nice!
01-19-2011, 08:09 PM
#3
That rhythm is INFECTIOUS. |
Pickerington OH |
16,883 |
Cool! Gotta subscribe to this one too...
01-19-2011, 08:21 PM
#4
NEVER NEUTRAL |
Delaware |
Model: intrepid |
Color: PBQ |
6,548 |
sweet!!
01-19-2011, 08:28 PM
#5
Va Beach, VA |
Model: ES- Special Tricks |
9,694 |
That's sweet! I'll watch this build also. Only if Mother Mopar release the engine coding.
Late!
01-19-2011, 08:32 PM
#6
yippee ki yay |
Fort Worth, TX |
Model: Fleet of LH cars |
Color: multi color |
5,810 |
purdy...i'll be watching.....
01-19-2011, 08:50 PM
#7
sycamore, IL |
Year: 1998 |
758 |
ill be watching this as well
01-19-2011, 09:04 PM
#8
georgia |
Year: 2004 |
Model: Intrepid Police Pkg |
Color: Midnight blue pearl |
5,622 |
nice !!!
01-19-2011, 11:41 PM
#9
Sudbury, Ontario |
Model: Intrepid SXT |
Color: Bright Silver PS2 |
12,440 |
What he said!
01-19-2011, 11:44 PM
#10
Greater Pittsburgh, PA |
Model: Intrepid "Superbee" |
Color: PEL Sechs |
14,568 |
Oooooooooo, purdy!
01-19-2011, 11:57 PM
#11
Atlanta |
Model: Intrepid ES |
Color: Onyx Green |
2,045 |
holy geez....two 4.0L storkers?!
And what Scooter said....man, if we had access to the PCM the things we could make this car do....and a good tranny that could handle all the power. lol
01-20-2011, 01:03 AM
#12
Charleston, SC |
Year: 2004 |
Color: Sexy |
4,491 |
I have a question about case depth/hardness on the journals.
My company makes Turbos. For durability purposes, on the turbine wheel shaft we harden the diameter so that after final grinding we have a specific hardness and case depth.
By removing so much material from the mains, are you concerned you may have ground off the harness band from the original manufacturing process? By chance did you have the hardness tested before or after the machine shop work ?
01-20-2011, 06:45 AM
#13
Farticcus of Plenticcus |
39.188626,-84.661524 |
Year: 2004 |
Model: 300M Special |
Color: PDR |
15,752 |
Awesome....
01-20-2011, 06:46 AM
#14
Panama City, FL |
1,203 |
Good question. I did not. It is my understanding that forged steel cranks are not hardened on any of the journals as the original material is supportive enough. I think in the old days they did harden cast craks since the journals were more malleable, but metallurgy has kept pace with technology and some of the new alloys are far superior to what we had 20 or 30 years ago. In turbos you are dealing with much higher heat, much higher rpm's than a crankshaft sees, so I could understand hardening it. If I'm wrong, I'll be the first to post pics of spun bearings or hacked up mains.
__________________
01-20-2011, 06:53 AM
#15
Panama City, FL |
1,203 |
I've been talking to a guy from Vitesse Racing who is a distributor of Perfect Power products. They build a piggyback unit that I'm told will work with our PCM's to modify the inputs so that you can vary fuel and spark and other sensors. The only review of one so far is on a 3.3 equipped minivan (which they claimed worked well) but if I give it a try I'll be posting the results. The piggyback unit has only 6 wires to splice to the pcm harness and is variable/adjustable so you can set up and monitor the inputs through a laptop connection to the DRB.
__________________
