2001 SE 2.7 ac low side static pressure reading
My ac isn't cooling, I added freon, and my static pressure was 65 psi, I checked it more than once to make sure. I have conflicting information about static pressure, one source says normal static pressure is 80-100 psi depending on weather, and another source says the static pressure on the low side is only slightly higher than the actual pressure when the car is on and the compressor is engaged, which is true? tomorrow I'll check the cooling power of the ac when I'm driving to school, I got the static pressure down to 42-45 psi, is this too low or just right? Thank you guys
Sorry for reposting this from a previous thread, everybody went hush hush on me.
