02-15-2012, 02:08 AM
#1
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
Acronyms/abbreviations used here
MODs - Please edit this post as needed to combine new postings, and please move to best section and sticky as seen fit.
I think that there could be some benefit for new users (and some old hands too) to have a list of acronyms and abbreviations used here on the board. Either car related (PCM) or chat related (IIRC). List should be complied every so often and alphabetized to make it easier to search maybe? Please add to and correct as needed!
1G - First Generation (1993-1997)
2G - Second Generation (1998-2004)
ABS - Acrylonitrile Butadiene Styrene (black plastic, often used in piping and other automotive plastic needs) (See PVC)
ABS - Automatic Braking System (See TCS) (See Trac) (See CAB)
AC - Air Conditioning
AC - Alternating current (household power) (See DC)
ADI - If you rock a white belt and have really loud Thubz
ASD - Automatic Shut Down
AT - Automatic Transmission (See MT)
ATC - Automatic Temperature Control (See MTC)
BBL - Be Back Later
BBS - Bulletin Board System
BCM - Body Control Module
BFH - Big F**kin Hammer
BFP - Big F**kin Pliers
BRB - Be Right Back
BSOD - Blue Screen Of Death (See Dick run? Run Dick, run!)
BTW - Blue Tipped Wrench
BTW - By The Way
Byte - eight bits used to define a single character, with each bit set to 0 or 1, thus providing 256 unique single characters (See Kb)
CAB - Controller Antilock Brake (See ABS)
CAI - Cold Air Intake
CD - Compact Disc (See DVD)
CDMcCull - Cean Daniel McCull... (first initial, middle initial, and first six letters of last name)
CEL - Check Engine Light (See DTC)
CKP - Crankshaft Position Sensor (See CMP)
CMP - Camshaft Position Sensor (See CKP)
COP - Coil On Plug (See DIS)
DC - Daimler Chrysler
DC - Direct current (battery power) (See AC)
DI - DodgeIntrepid(.net)
DILLIGAF - Does It Look Like I Give A F**K
DIS - Distributorless Ignition System (See COP)
DOHC - Dual Over Head Cam (See OHC) (See SOHC)
DPDT - Doube Pole Double Throw (See SPDT)
DRB(I, II, III, etc) - Diagnostic Readout Box
DRL - Daytime Running Lights
DS - Dark Slate
DTC - Diagnostic Trouble Code*(See CEL)
DVD - Digital Versitile Disc (See CD)
ECM - Engine Control Module (See ECU) (See PCM)
ECU - Engine Control Unit (See ECM) (See PCM)
EGR - Exhaust Gas Re-circulation
EMF - Electro Magnetic Frequency
EVAP - EVAPorative emission controls (fuel vapor)
FDD - Floppy Disk Drive (See HDD)
FFDP - Five Finger Death Punch (See Fred) \m/*
FP - Fuel Pump
FPR - Fuel Pressure Regulator
Ft. Lbs. - Foot Pounds (rotational torque) (See In. Lbs.)
FTL - For The Loss
FTMFGDW - For The Mother Fu**in' G*ddamn Win!
FTW - For The Win
FUBAR - F**ked Up Beyond All Recognition (censored)
FWIW - For What It's Worth
FYI - For Your Information
Gb - GigaByte (a measure of memory capacity, 1024 Mb) (See Mb) (See Tb)
GTFO - Get The F**k Out
HD - High Definition (See HDD)
HDD - Hard Disk Drive (See HD) (See FDD)
HDMI - High-Definition Multimedia Interface (See VGA)
HMFWBIC - Head Mother Fugger Who Be In Charge
HSM - Heated Seat Module
IAC - Idle Air Control
IDGARA - I Don't Give A Rat's A**
IIRC - If I Remember Correctly
IMHO - In My Humble Opinion
IMO - In My Opinion
In. Lbs. - Inch Pounds (rotational torque) (See Ft. Lbs.)
InHG - Inches of Mercury
IOW - In Other Words
ISCA - Iowa Studen Computer Association
Kb - KiloByte (a measure of memory capacity, 1024 bytes) (See Byte) (See Mb)
Kg - Kilograms
Lbs - Pounds
LH - Another website (See DI)
LH - The fine automobile family (platform, chassis) designation this website celebrates, covering Dodge Intrepid, Eagle Vision, Chrysler Concord/LHS/New Yorker/300M.
LOL - Laughs Out Loud (like we ever do that!) (See ROFLMAO)
LX - The next series design spawned from the LH platform
MAP - Manifold Absolute Pressure
Mb - MegaByte (a measure of memory capacity, 1024 Kb) (See Kb) (See Gb)
Mod - Moderator
Mod - Modification or customization
MSM - Memory Seat Module
MT - Manual Transmission (See AT)
MTC - Manual Temperature Control (See ATC)
MTV - Manifold Tuning Valve (See SRV)
MTV - Music TeleVision (See VH1)
OHC - Over Head Cam (See DOHC) (See SOHC)
OSH - Oh Sh!t Handle
PCI - Programmable Communication Interface
PCM - Power-train Control Module (See ECM) (See ECU) (See TCM)
PCV - Positive Crankcase Ventilation (See PVC)
PDC - Power Distribution Center
PEVA - Respected knowledge base and clairvoyant about when his name is posted to the site.
PL - Power Locks
PM - Private Message
PS - Power Steering
PSI - Pounds per Square Inch
PVC - Poly Vinyl Chloride (white plastic piping)*(See ABS) (See PCV)
PW - Power Windows
RIP - Rest In Peace
RKE - Remote Keyless Entry
ROFLMAO - Rolls On Floor Laughing My A** Off (like how often does that really happen?) (See LOL)
RTFM - Read The F**kin Manual
RTV - Room Temperature Vulcanizing - AKA silicone sealant (but may not be technically silicone), gasket maker
SBEC - Single Board Engine Controller (See PCM) (See ECU) (See ECM) (See SMEC)
SKIM - Sentry Key Immobilizer Module (See VTSS)
SMEC - Single Module Engine Computer (See PCM) (See ECU) (See ECM) (See SBEC)
SOHC - Single Over Head Cam (See DOHC) (See OHC)
SPDT - Single Pole Double Throw (See DPDT)
SRS - Supplementary Restraint System (air bags)
SRV - Short Runner Valve (See MTV)
SS - Stainless Steel
STFU - Shut The F**k Up
Tb - TeraByte (a measure of memory capacty, 1025 Gb) (See Gb)
TB - Timing Belt
TC - Torque Converter
TCM - Transmission Control Module (See PCM)
TCS - Traction Control System (See ABS) (See Trac)
TPS - Throttle Position Sensor (or TPS report, which needs to have a cover sheet)
Trac - Traction Control (See ABS) (See TCS)
TTT - To The Top (bump)
VGA - Video Graphics Array (See HDMI)
VH1 - Video Hits 1 (See MTV)
VTSS - Vehicle Theft / Security System (See SKIM)
WP - Water Pump*
WTF - What The Fu** (censored) (See WTH)
WTH - What The Hell (See WTF)
YMMV - Your Mileage May Vary
Reason: Definitions Added
02-15-2012, 06:17 AM
#2
Va Beach, VA |
Model: ES- Special Tricks |
Color: Stone White |
9,692 |
SKIM – Sentry Key Immobilizer Module
VTSS – Vehicle Theft / Security System
SBEC = PCM
DTC – Diagnostic Trouble Code
RKE – Remote Keyless Entry
DRBIII - Diagnostic Readout Box
PCI – Programmable Communication Interface
CAB – Controller Antilock Brake
Trac – Traction Control
MSM – Memory Seat Module
HSM – Heated Seat Module
02-15-2012, 09:49 AM
#3
Garrison, ND |
Year: 1994 |
15,412 |
RIP - Rest In Peace
I'll combine and catalog all these tonight.
Others? More? Keep them coming. Thanks Fred for the additions to my post! ahahaha Thanks for the great addins Chris.
02-15-2012, 10:19 AM
#4
Michigan |
Model: '98 Intrepid ES 3.2L |
427 |
02-15-2012, 10:20 AM
#5
Garrison, ND |
Year: 1994 |
15,412 |
What about PC Load Letter? WTF is PC LOAD LETTER!!!!
Thanks Joe!
02-17-2012, 10:52 AM
#6
Garrison, ND |
Year: 1994 |
15,412 |
FWIW - For What Its Worth
IMO - In My Opinion
02-17-2012, 12:34 PM
#7
Lowell, IN |
Year: 1995 |
Model: Eagle Vision TSI PHP |
Color: Char-Gold Satin Met |
1,634 |
How about CDMCCUL ?
02-17-2012, 06:27 PM
#8
Garrison, ND |
Year: 1994 |
15,412 |
HEheheheh
CDMcCull - Cean Daniel McCull... (first initial, middle initial, and first six letters of last name, but according to North Dakota, my middle name isn't Daniel - gotta work on getting that fixed - some vital records in Iowa were destroyed in the flood, so I'm waiting for other ways to prove my name change from birth)
02-24-2012, 02:34 AM
#9
Garrison, ND |
Year: 1994 |
15,412 |
There, put them in order finally.
Special thanks to:
Fred
Chris
Joe
Ken
More? More more?
02-24-2012, 11:25 AM
#10
Michigan |
427 |
Just a little correction ... you listed Kb, Mb, Gb, Tb for kilobyte, megabyte, gigabyte, terabyte. Those B's should be capitalized.
Lowercase 'b' = bit (binary digit) = a 0 or 1; usually used for network speed (100 Mbps, 1 Gbps, etc.) <-- Mbps = megabits per second
Uppercase 'B' = byte = 8 bits; usually used for storage capacity (512 MB, 4 GB, 2 TB, etc.)
Just wanted to clear that up
02-24-2012, 11:30 AM
#11
Garrison, ND |
Year: 1994 |
15,412 |
Ah - Very good, thank you. I will go fix that. Forgot about how bit would be lower, and byte would be upper.
02-24-2012, 11:38 AM
#12
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,129 |
Here's one for ya Cean lets see if you ca figure it out lol.
DILLIGAF.
02-24-2012, 11:39 AM
#13
Garrison, ND |
Year: 1994 |
15,412 |
Ty, Does It Look Like I Give A F**k if you challenge me like that?
ROFLMAF!
02-24-2012, 11:42 AM
#14
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,129 |
Nice job not allot of people know that one lol.
02-24-2012, 12:26 PM
#15
A place Called Home |
Year: 1997 |
9,609 |
How about this: IDGARA
