I have a 03 special. I had some mud flaps (molded one's) I used a dremel tool to change the contours around the lower cladding. It looks like it was made for the special. So with a little work, it can be done. If you get the flat mud flaps the job is easier. I will agree they can scrape if mounted too low.
