07-08-2012, 12:57 AM
#1
Intrepid Fan |
Michigan |
Model: Intrepid SE |
Color: White |
159 |
Rust along bottoms of doors...truck bedliner?
So, reading around here, this seems to be quite a common problem...I was wondering if anyone's ever hit their inner door rust spots with some kind of truck-bed liner, like Line-X or Rhino Lining.
This stems from an idea I had of going around the fender and down to the rocker panels with Rhino Lining to prevent scratches and bumps. Looking at the rust, I thought if I did that, maybe I should just hit the bottom of the door as well. Plus, it would look pretty badass ATMO...a white car with some black trim on the bottom
Then maybe I could ditch the silver hubcaps and finally put those damn NASCAR decals on my car (only partially joking).
07-08-2012, 03:10 PM
#2
Squilly's Jubilant Buttocks |
Holland, MI |
Model: Intrepid ES 3.2L |
14,192 |
Just got to be careful not to hit the window stuff. I'm not sure, I've been meaning to look into something like this. Rust is eating up my doors too. :(
07-08-2012, 05:39 PM
#3
Osceola, IA |
Model: 300m |
447 |
I just ground the rust off the bottom of my drivers side door then painted over it 2 weeks ago
07-08-2012, 10:45 PM
#4
Holland, MI |
14,192 |
^^ yeah, I did that too... didnt even last one winter. Need to try some Eastwood rust encapsulator.
07-08-2012, 10:49 PM
#5
Mag-Tard! |
Tiny Pebble, AR |
Model: 300m Special |
Color: Crappy! |
25,716 |
What about this stuff? I thought a few people have already used it?
http://www.por15.com/
07-08-2012, 11:07 PM
#6
get off my lawn |
Smyrna , Tn |
Model: 300M Special |
Color: PS2 |
13,921 |
por 15 is great stuff,, been around for years and usually does the trick
07-08-2012, 11:11 PM
#7
Mag-Tard! |
Tiny Pebble, AR |
Color: Crappy! |
25,716 |
What do I know? LOL! I was going to order some for the Ricer drivers front door but ended up replacing the entire door so no need for it now. There were rust stains on the plastic door sill cover/skirt from the original door as shown in the picture below. The rust was coming from the crimped metal bottom of the door. I haven't taken a good look at the original door yet. The moisture shield on the inside of the door was completely intact along with all the weatherstripping etc. I suspect a clogged door water drain for this. No rust like that on the Passenger Front door or either of the rear doors.
__________________
"Just Junk It LLC." Snobby Luxury at it's Worst! Member of theTwin Magnums of DI.net! Perky Jerky for Everyone!! Crazy Rons House of Mega Deals
07-09-2012, 06:54 AM
#8
Intrepid Fan |
Michigan |
Color: White |
159 |
I mean, the rust isn't deep. I'll have to look into POR-15 though.
07-09-2012, 10:28 AM
#9
Sudbury, Ontario |
Model: Intrepid SXT |
Color: Bright Silver PS2 |
12,415 |
I've cleaned up the doors on my Intrepid, they were pretty bad. I ended up cleaning the rust off with a wire brush, cleaning it with solvent, taping it and then painting on a coat of POR-15. The problem with this rust spot is that the rust is actually coming from the inside of the door or crimp, it's not surface rust. A better way of doing it would be to get inside of the door and apply the POR-15 in there along with the outside too and hope that you sealed it all. And even then, there's no guaranty that it would 100% stop it. The only for sure way to do it is to either replace the door with a new one or have the lower lip pealed back, blasted/cleaned up, re-sealed and re-assembled, very expensive.
07-17-2012, 11:08 PM
#10
Intrepid Fan |
Michigan |
Color: White |
159 |
One question about the door rust...I've read several sources saying that rust like mine is indicative of a plugged drain hole in the bottom of the door. My concern about that is about the timing of it all. All 4 of my doors started to rust right around the same time, shortly after winter. If it truly was a plugged drain hole in each of the doors, wouldn't the doors have started rusting at different times?
07-18-2012, 12:09 AM
#11
Intrepid Fan |
Maine USA |
Color: Toxic Orange Pearl |
119 |
In short, hit the rust before it get's bad. Grind it spotless, epoxy primer it, lay the rockguard/rhino liner etc. then paint over if you wish. Won't have to worry about it again if you cleaned the rust right.
Rust sucks.
07-23-2012, 09:10 PM
#12
Intrepid Fan |
Michigan |
Color: White |
159 |
I was at Autozone today, chatting with an old friend from high school who worked there. He pointed me towards some Rust-Oleum rust remover, and suggested the quart of Herculiner for doing what I had described to him...he's actually done a similar thing to his car, and had good results.
Now...does anyone have a DODGE stencil, or something die-cut that I can paint onto the car using the bedliner?
07-23-2012, 11:16 PM
#13
Holland, MI |
14,192 |
I tried the rustolium rust stuff. Didnt work for crap. Will be trying again with eastwood encapsulator sometime this summer.
07-25-2012, 05:24 PM
#14
Sudbury, Ontario |
12,415 |
Once again, the rust is coming from inside the seam, you can clean the outside all you want but it's still going to come back through.
07-26-2012, 08:49 PM
#15
Intrepid Fan |
Michigan |
Color: White |
159 |
So, what do you recommend? I mean, from the standpoint of someone who doesn't have a fresh stack of 'Trep doors hanging around. Am I just supposed to live with it?
