Originally Posted by craigibc
It is a rod bearing issue. I tore the engine down yesterday.
Sorry for the bad news!
I'm curious though, have you recently replaced the water pump? If so, did it dump coolant into the motor oil? I've seen at least three cases recently where the oil was milkshaked from the water pump. then had major bearing failure right after that. Even though the oil was replaced in a timely manner and the pump was replaced too.
I'm starting to make the recommendation that engine bearings be replaced if the water pump causes any milkshake.
