first, try filling it cold with the bleed valve open,, untill coolant runs out with no bubbles, if you try to do it with the car running , too big of a chance of keeping air in the system, second,, if it seems like the coolant is not reaching the engine,, id suspect thermostat , or waterpump, why water pump?? well, its ran by the timing belt,, it can get stiff to turn, and slip on the belt,, thus reducing coolant flow.
thermostat,, can become stuck in the closed postion,, , just a couple of things to take a peek at
