07-29-2012, 04:54 AM
#1
Intrepid Newbie |
Lancaster, CA. |
Model: Intrepid se |
Color: wht |
7 |
Newbie Here with my first 2002 dodge Intrepid
Hi All,
Finding great info. on this sight and since I just got my 2002 Dodge Intrepid 2 months ago and already having tranny issues I'm glad Ive found this sight....
07-29-2012, 10:18 AM
#2
Squilly's Jubilant Buttocks |
Holland, MI |
Model: Intrepid ES 3.2L |
14,173 |
welcome! Have you gotten the underlying codes pulled?
07-29-2012, 11:50 AM
#3
Greater Pittsburgh, PA |
Model: Intrepid "Superbee" |
Color: PEL Sechs |
14,560 |
Welcome from a fellow 02 owner! Yeah, doing the key dance will get you a P0700. Go to an Autozone if you can and scan for the underlying p0700 codes
07-29-2012, 05:20 PM
#4
Intrepid Newbie |
Lancaster, CA. |
Color: wht |
7 |
Hi All
I took it in for a diagnostic test and there telling me I need a whole new transmission..GRRRR
The codes that came up are P1776, P0440, P0456, And there telling me he OD clutch volume Index was 122 "which they say is way out of specs"
07-29-2012, 06:34 PM
#5
get off my lawn |
Smyrna , Tn |
Model: 300M Special |
Color: PS2 |
13,917 |
po440 and 456 are evap codes,, dont worry about them yet
1776,, either valve body, or solonoid pack, common items
07-29-2012, 07:22 PM
#6
Intrepid Newbie |
Lancaster, CA. |
Color: wht |
7 |
2002 Dodge Intrepid Tranny
Any Idea what the specs on the OD clutch volume Index should be? Mine is at 122. How do u repair this?
07-29-2012, 09:42 PM
#7
Holland, MI |
14,173 |
you're mechanic is a quack. They're trying to hose you. search the site for P01776.
07-30-2012, 06:04 AM
#8
Color: PEL Sechs |
14,560 |
The 1776 code is very common on 02-04 trans'. Depending on the manufacture date of the valve body, it could either be that or the solenoid pack. But if you're going to have somebody else work on your car, I wouldn't trust that garage with a Metro by the sounds of it.
Sent from my DROID RAZR using AutoGuide.com App
07-30-2012, 04:55 PM
#9
LH Tinkerer |
East Saint Louis Co |
Year: 2003 |
Color: Silver |
1,392 |
122 is perfectly normal for O/D. Not any of the others but, Certainly O/D can be upwards of 140 and still be in spec.
07-31-2012, 01:14 PM
#10
Va Beach, VA |
Model: ES- Special Tricks |
Color: Stone White |
9,678 |
Welcome aboard! Good luck with the tranny issue. Do a search as stated above, it the valve body or solenoid pack.
Late!
07-31-2012, 01:56 PM
#11
Canuckistanian Resident |
Saskatchewan Canada |
Year: 1999 |
Color: Red? |
3,688 |
Welcome to the board!! Good luck with the transmission.
08-01-2012, 12:57 AM
#12
Intrepid Newbie |
Lancaster, CA. |
Color: wht |
7 |
Thank You Everyone
After a long day and $440. dollars later my 2002 Dodge Intrepid transmission is driving smoothly. Thank you everyone for the very helpful advice. Things can only look up from here...
08-01-2012, 01:45 AM
#13
Grab Your Bitch By The Horns |
Oceanside, NY |
Year: 2004 |
Model: Intrepid Police Pkg. |
Color: PB8 |
5,299 |
Welcome to the forums!
