08-22-2012, 09:05 PM
#1
Intrepid Newbie |
Florida |
Color: Maroone |
2 |
Starting problem
I have a 2001 Intrepid with 176K miles on it..Runs tip top...little smoke leaving red lights...My car won't start in the morning or after it sits when it gets cold....have to crank it a few seconds turn off ignition do it again starts right up....once its warm it starts up.... if I turn it off like to go into a store ..it will start up right away...Just problem with cold start...Why?.what the hell....fuel pump?
08-22-2012, 09:13 PM
#2
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
What happens of you just always cycle the key a few times, not cranking it, then try starting?
Sent from my SCH-S720C using AutoGuide.Com Free App
08-23-2012, 06:03 AM
#3
Virginia, U.S. |
10,272 |
Cean's on it like a Duck on a June bug!
Jaybird - what engine do you have - 2.7? If so, the smoke out the exhaust may be bad valve stem seals. Also thoroughly check out and restore the PCV system.
08-23-2012, 12:48 PM
#4
Planet Earth, Milky Way Galaxy. |
Year: 1995 |
Model: Intrepid ES 3.5L |
Color: Spruce Metallic PPE |
1,748 |
Little smoke leaving red lights = soot. Floor it to the Red Line and the problem subsides. It worked for me.
DISCLAIMER: I am not responsible in the event of a blown engine. It worked for me, while red-lining may not work for someone else.
08-23-2012, 12:57 PM
#5
Mag-Tard! |
Tiny Pebble, AR |
Model: 300m Special |
Color: Crappy! |
25,679 |
What does that have to do with his starting problem.
08-23-2012, 01:14 PM
#6
Year: 1995 |
1,748 |
I don't know about the starting, but all you can do is try.
08-23-2012, 01:44 PM
#7
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,126 |
This is a bad idea and is not ah fix for anything.
One day someone will damage there vehicle taking advice like this and it will be all your fault.
Please leave the diagnosis of these type of problems to those who have dealt with them and know what they are talking about.
08-23-2012, 07:27 PM
#8
Garrison, ND |
Year: 1994 |
15,412 |
Not to validate the idea of aimlessly flooring your engine, but that is after all basically what an Italian Tune-up is...
08-23-2012, 07:30 PM
#9
Mag-Tard! |
Tiny Pebble, AR |
Color: Crappy! |
25,679 |
He's not even old enough to drive the car legally. Wonder who he's advising to do that stuff on the car in his sig pic?
08-23-2012, 08:18 PM
#10
get off my lawn |
Smyrna , Tn |
Model: 300M Special |
Color: PS2 |
13,919 |
Pay no attention to the young one up there ^^^^ he is the kind that would put a coffee can on a rolls royce...
ok that being said,, blue smoke at start up,, valve seals, if your not using much oil,, id let it go for a bit, but the hard start in the morning,, yea,, is go for the fuel pump,, its draining down over night,,, like they said above,, turn the car on in the morning,, dont start,, turn off do it a few times,, wait 10-15 seconds, between on and off,, if it starts right up,, bingo,,
__________________
If you want to be a clown, go join a circus
08-23-2012, 08:29 PM
#11
Intrepid Newbie |
Florida |
Color: Maroone |
2 |
Hey thanks...176K car drives like its new.... smoke not affecting performance at all...I might need a half quart of oil every couple weeks...not bad at all... I live in south Florida and the A/C don't work...I'm afraid to invest $ with so many miles on the car....It drives great accept the cold start which is no big deal.... It always cranks up after I turn off ignition to restart it. 2nd time....Appreciate any advice....not sure but someone must of maintained this engine...I bought it a year ago from a friend who moved to Venezuela....
08-23-2012, 08:58 PM
#12
Virginia, U.S. |
10,272 |
...ok that being said,, blue smoke at start up,, valve seals, if your not using much oil,, id let it go for a bit, but the hard start in the morning,, yea,, is go for the fuel pump,, its draining down over night,,, like they said above,, turn the car on in the morning,, dont start,, turn off do it a few times,, wait 10-15 seconds, between on and off,, if it starts right up,, bingo,,
I agree with all of that, but would add that, besides a fuel pump issue, the hard start can also be a leaky fuel injector. In both cases the rail ends up empty with air in it after it sits a while/overnight. The way to tell the difference is that if a leaky injector, you will smell raw fuel out the exhaust when it does first start (due to cylinder(s) with leaky injector(s) being flooded), and if fuel pump leak down, you won't get the raw fuel smell (all cylinders will be way lean).
08-23-2012, 10:11 PM
#13
get off my lawn |
Smyrna , Tn |
Color: PS2 |
13,919 |
I agree with that also,,, of course,, with a leaky injector,, he would get a miss in the cold start,, no mention of that
08-24-2012, 05:51 AM
#14
Virginia, U.S. |
10,272 |
Did you mean to say warm start there? I'm thinking that a small leak - big enough to partially empty the fuel rail overnight - may or may not be big enough to cause a miss on warm start - or maybe if he listens/feels for it there is one? On the problem cold starts (after key cycling), it should sputter if the cause is either the fuel pump or injector leak down - all cylinders too lean/getting air bubbles if fuel pump leakdown, only the leaky injector cylinder(s) flooded, all other cylinders lean with leaky injector(s).
08-28-2012, 09:52 AM
#15
Novato CA |
Year: 1998 |
Model: Intrepid ES 3.2 |
Color: Bright Platinum |
609 |
Hard start, as you describe, is usually the result of loss of residual fuel pressure on shut down. Vapor forms inside the fuel lines as the fuel boils from engine heat soak creating a vapor lock condition.
A leaky fuel pump check valve is the usual suspect which means you'll need to replace your fuel pump.
