09-27-2012, 02:12 PM
#1
Intrepid Newbie |
Montréal |
Year: 1999 |
Color: Red |
6 |
Hi
Hi my name is Jessy and i have a 1999 Chrysler Intrepid ES whit a 3.2L Engine. I love my Intrepid and take care of it but like any other car i have some problem whit it.
The computer give me the error p 0300-0301 that is the misfire code in the #1 cylinder but im not sur what to do whit that.What do i need to change or repair. Thanks for help.
09-27-2012, 02:19 PM
#2
Beer-like Attitude |
Bat Cave, NC |
Year: 1999 |
Model: Intrepid ES |
Color: Green |
607 |
Welcome! Here it a thread to get you started. This guy has the same code error, so maybe his thread will help you get started. Good luck!
Reason: correct spelling
09-27-2012, 04:23 PM
#3
Osceola, IA |
Model: 300m |
445 |
I would start off by swapping the # 1 coil pack with one of the others (would also be a good time to check the sparkplug), clearing the code, then running it and seeing if the code moves to the cylinder that you moved the coil pack to. Next thing that I would suspect would be the # 1 cylinder fuel injector.
09-27-2012, 08:03 PM
#4
Squilly's Jubilant Buttocks |
Holland, MI |
Model: Intrepid ES 3.2L |
14,177 |
welcome!
09-28-2012, 12:06 AM
#5
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
Welcome aboard!!!
09-28-2012, 12:31 AM
#6
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,126 |
Welcome to the site!!!
09-29-2012, 12:08 PM
#7
Planet Earth, Milky Way Galaxy. |
Year: 1995 |
Model: Intrepid ES 3.5L |
Color: Spruce Metallic PPE |
1,748 |
Welcome to the only site with Intrepid in it's name!! +rep for new members!!
10-01-2012, 02:42 PM
#8
Intrepid Newbie |
Montréal |
Year: 1999 |
Color: Red |
6 |
spark plug
Ok i change the #1 spark plug and the chek engine light went off and my idle is no more rought the car run relly great but im still having the error code. How do i clear it? Sorry i just know how to do the key dance and bring the code im not an expert in dodge car but i want to know more of it.
10-01-2012, 03:22 PM
#9
Osceola, IA |
Model: 300m |
445 |
disconnecting the battery for 15 minutes should be long enough to clear the code. you will get a code for disconnecting the battery after that, but that's ok. it will go away eventually. you can disconnect the battery at the (-) jump post. it's easiest to do it there.
10-01-2012, 03:37 PM
#10
Intrepid Newbie |
Montréal |
Year: 1999 |
Color: Red |
6 |
clear it
ok thanks i already have the p 1684 battery code. Im gona try to clear it tonight. Thanks to help me whit that  .
