10-01-2012, 12:14 PM
#1
Cape Cod |
Year: 1999 |
Model: Intrepid ES |
Color: Silver |
251 |
Inner tie rod bolts
1999 Intrepid. I installed a rebuilt steering rack 6 months ago. Both inner tie rod bolts simultaneously broke off rack. Locking tabs still in place. Original torque was 60. Now I see it has been revised to 74. Was that my problem?
10-01-2012, 12:21 PM
#2
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
When the rack was replaced, do you know for a fact you got the shuttle and spacer both bolted through at both tie-rods?
I don't know if that'd be your problem or not - I don't think I even set mine to a specific torque when I put mine in! I wonder what I did... hrrrm...
10-01-2012, 12:42 PM
#3
Cape Cod |
Year: 1999 |
Color: Silver |
251 |
Yes, it was installed properly. I read that there was an update to the FSM stating that new torque must be 74 vs 60......even with locking tabs engaged.....there could be a problem.
10-01-2012, 12:57 PM
#4
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,126 |
On a 1st gen they should be at 55 foot pounds.
10-01-2012, 01:15 PM
#5
Bad Ass |
Ohio |
Year: 1910 |
Color: Light Almond |
21,013 |
were you driving this car at the time, like as in going around a corner? I also wonder if you replaced the bolts. Some kits come with new bolts. Mine did not. I could see the bolts being inferiour grade and shearing. What do you mean they broke off?
10-01-2012, 03:22 PM
#6
Cape Cod |
Year: 1999 |
Color: Silver |
251 |
I was backing up and started to cut the wheel. Heard a bang. Reached into both wheel wells and inner tie rod ends were loose as a goose and disconnected. Haven't pulled it apart yet. Yes, I did use original bolts. Good thing I wasn't on the road or the highway!
10-01-2012, 03:45 PM
#7
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,126 |
Im not sure if this had anything to do with what has happened with your car but when i replaced my rack i didn't notice that when i remounted the tie-rod ends the washers in between the bushings and inner rack were pinched over the lip of the rack boot and the movement turning left and right eventually freed them causing the bolts to be instantly be loose.
I did catch mine before any damage happened but when you fix yours again its something to pay attention to.
10-01-2012, 06:54 PM
#8
Bad Ass |
Ohio |
Year: 1910 |
21,013 |
Thank God! Scary!
10-01-2012, 06:57 PM
#9
Bad Ass |
Ohio |
Year: 1910 |
21,013 |
Okay, I have seen this once. A guy used an inch pound torque wrench instead of foot pounds!
10-01-2012, 07:59 PM
#10
Lowell, IN |
Year: 1995 |
Model: Eagle Vision TSI PHP |
Color: Char-Gold Satin Met |
1,629 |
Happened to me once and I think it must have been my fault. I think I had the rubber pinched between the bolts. I ended up having to replace the rack.
10-02-2012, 05:23 PM
#11
Bad Ass |
Ohio |
Year: 1910 |
21,013 |
Any more on this issue?
10-02-2012, 05:34 PM
#12
Cape Cod |
Year: 1999 |
Color: Silver |
251 |
Both bolts broke off in rack. Dodge has a bulletin out saying that the torque needs to be increased from 60 to 74 and newer bolts are available to handle it. They're saying that at 60 the bolts are loosening up, even with lock tabs bent over, and causing them to snap under stress. Gonna do it tomorrow. Nice pic.
10-02-2012, 05:55 PM
#13
Osceola, IA |
Model: ES, 300m |
2,448 |
I doubt if the torque value was the problem, unless of course they weren't even close to tight. I have done inner tie rods several times and never used a torque wrench. I don't even think there is room for one.
10-02-2012, 06:04 PM
#14
Cape Cod |
Year: 1999 |
Color: Silver |
251 |
Go to google. there's a site complaining about huge problems out there re snapping bolts on the inner tie rods for our cars. They say that the torque fix is BS. I had replaced the rack 8 months ago and torqued the original bolts to 60. They snapped. Doing it again with new bolts to 74 per bulletin. Yes, I fit a torque wrench in there last time.
10-02-2012, 06:16 PM
#15
Garrison, ND |
Year: 1994 |
15,412 |
I'm with Mike - Mine was done till my elbow went "click" - then I set the tabs... I've got multi-thousand miles on mine since.
