Hey guys,
So I recently purchased one of the original intake spacers from a club member and I plan on reproducing it. My idea is to use my intake spacer as a donor to be recreated digitally through some software I have access to at my University. Ideally, I should just be able to transfer measurements into the computer and then send the file over to a machine shop for production. I already have a good friend lined up to make the parts and I trust him to make a quality product. I have already worked with him in the past with the production of other parts and accessories.
Here are a few details about the spacer itself form previous threads..
It is an aluminum spacer that goes where the gasket between the intake plenum and lower intake manifold goes. It is shaped like the gasket but is thicker - 3/8" thick - so it raises the intake plenum up 3/8". The longer air flow path increases mid to high end torque.
It gives 30 ft-lbs of added torque in the middle rpm range
Originally Posted by SPAD3
Here are the dyno results. This mod is one of the few that are custom made. The are precision cut to match the lower intake perfectly. Over 35 are currently installed, with no returns.
It increases the runner length, lowering the power band, which adds to the torque. Its one mod you can feel the difference with. Some have *reported* a gain of 1-2 MPG. This is unconfirmed though. I noticed a 1 MPG change in my personal cars.
V2 Spacer - Image from Spad3
Current CAD model in progress...
Current Package Deals
Core Package - $150 + $15 core
- Intake Spacer
- Extended Bolt Set
- Altered Plenum Brackets ($15 core charge refunded when old brackets are mailed back)
99-early02 "EGR" Package - $150 + $55 core
- Intake Spacer
- Extended Bolt Set
- Extended EGR Tube ($40 core charge refunded when old tube is mailed back)
Core Gasket Kit - $24.50
- x2 MS91990 Plenum Gasket
- 61068 Throttle Body Gasket
99-early02 "EGR" Gasket Kit - $28.50
- 70720 EGR Mounting Gasket
- x2 72928 EGR Tube Seal
I wanted to start a list of those who are JUST interested in getting a V3 Spacer, this is not a commitment list, just a list for me to get an idea on who would be interested in buying one.
Updated List*
If you are interested add your name to the list below:
1. Austin R/T (DI)
2. Adpros (DI)
3. YesImLDS (DI)
4. DjGreggieP (DI)
5. Bigde024 (DI)
6. Kent Vice (300M Club)
7. 300M-Mike (300M Club)
8. hrmwrm (LH)
9. chosen3001 (300M Club)
10. srt420 (LH)
11. Henry (N/A)
12. Cornelius (300M Club)
13. SilverSpecial (300M Club)
14. 02SilverSpecial6.1 (300M Club)
15. Fromans4 (LH)
16. Avalancha805 (DI)
17. akiharho- ledgic_13 (300M Club)
18. '87IROCZOWNER69 (DI)
19. BiliTheAxe (DI)
20. Mopar340dave (300M Club)
21. BXZ (300M Club)
22. BatCaveTrep (DI)
23.
24.
25.
Thanks again,
-Ryan
