10-10-2012, 07:48 AM
#1
Intrepid Newbie |
Maryland |
Year: 1999 |
Model: Intrepid ES |
Color: Champagne |
25 |
Tie rod bushings
Found out yesterday that I need to replace the tie rod bushings on my 99 ES. It has 251K miles and these are the original bushings still in there. The service shop down the street quoted me a price of $540 that includes replacing the bushings and a four wheel alignment. Tech told me almost all of the cost is labor since the parts are very inexpensive. Now I have done various work on my car, (replaced brake calipers, pads, rotors, replaced radiator cooling fans, replaced wheel studs, drilled out broken studs), but never anything requiring removal of wiper blades and cowling. I have read through the forum and am deciding if it is a project I can complete on a Saturday afternoon. Any thoughts or suggestions?
10-10-2012, 07:53 AM
#2
May : Back in the office in Indianapolis |
Year: 2004 |
Model: Intrepid(Project 14) |
Color: Light Almond Pearl |
834 |
You can easily start and finish on a Saturday afternoon.
There is an excellent how-to on it: http://www.dodgeintrepid.net/showthread.php?t=210712
There is, absolutely, no reason to pay $540 to have this done.
The parts should be less than $25.
10-10-2012, 08:42 AM
#3
Beer-like Attitude |
Bat Cave, NC |
Year: 1999 |
Color: Green |
607 |
There is no need for an alignment if replacing the inner bushings. It also helps to have one front wheel off the ground, replace that bushing last, so you have free movement of the wheel. Removing the cowl and wipers, is just some screws, nuts and bolts. Although not require, but for ease, you may want to remove the plenum.
10-10-2012, 09:07 AM
#4
ct |
Model: intrepid es 3.2 |
Color: silver |
280 |
Really not that hard to do. Just did mine a week or so back. The cowl & cross member come off pretty easily. I did not have to raise the car or remove the plenum. Just turn the steering wheel all the way to the right, and that provides easy access to both bolts. Replace one at a time, so there is always one bolt in place (although you have to loosen to free the retainer up). Just make sure you replace the washer, bracket & retainer in the right order. Also, you may want to have someone there when you replace each of the bolts to nudge the steering wheel just a bit to properly center the bolt so it threads in smoothly. Don't want to cross thread. Then torque 'em up properly and you are good to go.
10-10-2012, 12:06 PM
#5
Intrepid Newbie |
Maryland |
Year: 1999 |
Color: Champagne |
25 |
Any chance I can get that part number for the bushings and where I can purchase it and also have it by Saturday. Thanks.
10-10-2012, 12:18 PM
#6
ct |
Color: silver |
280 |
Not sure of the part number, but you can get a kit pretty easily at Advance Auto..includes bushings, retainer, etc. I'd go with the Moog set. The old bushings might be a bit of a pain to remove since they are pressed in. I just used a pair of slip-joint pliers to break them apart. The new ones are two-piece and fit in from either side,with the metal sleeve through the middle. Also, when you tighten the bolts, be sure the rubber boot on the rack doesn't get caught up behind the washer.
10-10-2012, 01:57 PM
#7
Georgia, USA |
Year: 9804 |
Model: Intrepid ES / SE |
Color: PTE / PW1 |
2,433 |
MOOG Part # K7408
For $540 I'll fly up and fix it for you, parts included.
10-11-2012, 08:08 PM
#8
Intrepid Newbie |
Maryland |
Year: 1999 |
Color: Champagne |
25 |
Picked up Napa equivalent to the Moog part and will install on Sat. I will certainly post any questions or pleas for help if need be. Thanks again for the suggestions.
10-11-2012, 08:47 PM
#9
get off my lawn |
Smyrna , Tn |
Model: 300M Special |
Color: PS2 |
13,931 |
dont even have to remove the cowl,, turn the wheel all the way to the left,, remove the air box,, look!! theres the bolts,, ONE AT A TIME,,, 30-45 mins
10-12-2012, 12:02 AM
#10
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
What is the NAPA number you got?
10-12-2012, 09:46 AM
#11
Intrepid Newbie |
Maryland |
Year: 1999 |
Color: Champagne |
25 |
Napa part #274-9338
10-12-2012, 10:12 AM
#12
Intrepid Fan |
126 |
The worst part is removing the old stuff.
10-12-2012, 10:40 AM
#13
Garrison, ND |
Year: 1994 |
15,412 |
Thanks - I just ordered the K7408 equivalent, he charged me like $14 for them.
10-12-2012, 10:57 AM
#14
Year: 2004 |
834 |
Doctor, Doctor, Doctor, you do mean all the way to the right, don't you?
10-12-2012, 11:27 AM
#15
Intrepid Fan |
TN |
Model: Intrepid ES 3.2L |
Color: Deep Slate Pearl |
136 |
I would suggest laying a rag or cloth of some kind under the inner tie rod bolts.If you drop something or it falls out it will want to migrate down the transmission housing and its not easy to reach them there.
