10-11-2012, 01:48 PM
#1
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
Color: red soon to be black |
38 |
cradle mounts
So, all four of my front are worn but the front right upper is non existent. Will that make my car pull under heavy acceleration?
10-11-2012, 01:55 PM
#2
Lowell, IN |
Year: 1995 |
Model: Eagle Vision TSI PHP |
Color: Char-Gold Satin Met |
1,635 |
Without a doubt! Bad cradle bushings completely screw up the alignment as well as mess with the cv joints and trans mount
10-11-2012, 01:58 PM
#3
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
gotcha, so can you tell me the best way to replace? im gonna grab a set from poly and was thinking supporting the car from the sides and using a jack to do the front first then the rear lowering the cradle just enough to put them in.
10-11-2012, 02:52 PM
#4
Lowell, IN |
Year: 1995 |
1,635 |
Make sure you do a search, there are many good threads on this topic here.
I have done 4 sets myself without an assistant. The biggest challenge is getting the the bolts out because of rust. Thats a new can of worms and there are several ways to resolve it. You will have to loosen all of them so that there is enough play in the cradle to remove the upper bushing, work from side to side. What I mean is loosen all the bolts a bit and then loosen both drivers side a bit more, then do the front drivers side and then the rear, something like that. Then you can do one corner at a time like you suggested. The poly bushings fit tight. You need to reuse the metal from the old bushings and clean them up really well. Then getting the upper bushing in is a challenge. Grease it up good and make sure you don't tear them getting them in. Poly is tough but not indestructible. Car on good jack stands is a must and two floor jacks is better than one.
Good luck, post up with more questions
__________________
Mopar (+ a Ford) family
2010 F150 FX4 28k
2005 Stratus 2.7L 170k
1997 Intrepid Silver 3.3 170k
1997 Intrepid Sport 3.5 FranknTrep 195K/145K Engine
1995 Concorde Silver 3.5L117K
1995 Vision TSi 66K
1995 Intrepid 3.3 Dorothy 102K
1970 GTX 512CI
Pictures:
Vision
Intrepids
GTX
FX4
10-11-2012, 02:55 PM
#5
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
sounds good, I will post results
10-11-2012, 03:35 PM
#6
Michigan |
Year: 1994 |
Model: Concorde 3.3 L |
Color: Blue-green |
423 |
My upper bushings were rusted in bad. I found that an easy way to get them out is to grab around the metal piece with a pipe wrench and twist it up and out. If yours are seized in, this will save you a ton of time.
You should soak the bolts in PB Blaster ahead of time as well, there are access windows where you can spray it onto the tip of the bolt where it goes through the nut.
10-18-2012, 02:46 PM
#7
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
So i just purchased the poly bushings. should be here by next week. I checked the inner tie rod ends left was bad so i replaced the right was pretty solid and now neither have any play from what i can tell. The boots on the outer tie rod ends as well as the ball joints are worn but all are still fairly firm and do not need to be replaced. struts are new on the front. On the way to work this morning i hit 105. I had to hold the wheel fairly hard to keep it straight...its kinda all over the place. and if i let of the gas it tugs hard to the left before it straigtens out as well as the clunk sound. Im truely hoping its the cradle mounts otherwise im stumped.
10-18-2012, 03:36 PM
#8
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,129 |
Might also be the signs of a CV Axle going out but like you said wait till you get the cradle bushings replaced.
Why were you going a 105???
10-18-2012, 04:01 PM
#9
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
Well I have a new pair of half shafts but these seem pretty good as well. It's a 96 with only 67k on it
10-18-2012, 04:03 PM
#10
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
and I was going to 105 because I was really late lol
10-18-2012, 05:23 PM
#11
Georgia, USA |
Year: 9804 |
Model: Intrepid ES / SE |
Color: PTE / PW1 |
2,431 |
If you have suspension issues and drive 105, you might find yourself late forever...
10-18-2012, 05:35 PM
#12
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
no responce cause your right lol
10-23-2012, 01:55 PM
#13
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
does anyone happen to know what type of grease i should use for the poly bushings?
10-23-2012, 02:18 PM
#14
Lowell, IN |
Year: 1995 |
1,635 |
There is special poly bushing grease that is very glue like, its purpose is to prevent the poly from squeaking. I don't think its necessary in this application. I would just use regular grease to make inserting them in the frame easier. The grease wont hurt the poly, they are grease and oil resistant .
10-24-2012, 01:35 AM
#15
Intrepid Newbie |
Stockton |
Year: 1996 |
Model: vision tsi |
38 |
front came out and went in with no issues. burnt old mounts pieces off, cleaned the parts and re-installed all told 35 minutes but it got dark fast and didnt want to chance the backs. front tires stayed on the car, i used 2 jack stands and a floor jack. going to attack the rears tomorrow
