how easy to install you ask!
it was easy!
I cut a hole with my dremel in the console itself to install my sunroof switches.
installed switches.
i cut the roof with a utility knife on the inside border of the mounting plate in there, (way inside, I watched em take the console out of the other car so I had an idea on how large to make the hole)
removed visor to make installing wires easy, popped open fuse box, removed driverside (A pillar?) cover, pulled lights down from roof and disconnected.
I had the wiring harness, but wound up not using it, didnt need it, except for a guide on where to plugin what color wires into my existing harness.
the console has 4 wires to the computer itself, it's all you need. the rest of yer wiring is already there.
I tapped the pink wire into the pink wire that runs to the lights in the console.
I tapped the blue/white wire onto a blue and white wire as well that was already in my existing harness.
ran the other 2 wires (I forget the colors offhand but if u get a console u will see them) into the fuse box into the SAME spots as I removed them from the donor harness into my existing harness. use a pin or a small screw driver blade to pop the connectors out of the molded end to pop into existing harness with no hassle.
plugged everything into console as needed (lights, sunroof controls, Computer! a whopping 3 plugs), plugged harness back into fuse box, applied power and did the happy dance.
on a side note, I tested the console before i installed it to be sure it was gonna work out the way i described above.
this is really it in a nutshell..it was easy, and max 45 minutes work.
[ November 03, 2001: Message edited by: Thrasher ]
__________________
2004 Dodge Ram 1500 Quad Cab, HEMI! 20's, black, true duals, limo tint.
used ta have a 2k1½ Intrepid R/T Motorsports 1 of 383.
Flame Red, Sunroof, Infinity Audio w/Changer, EVIC+, Tire pressure sensors,
DynoMax Super Turbo Dual Exhaust system, De-Badged,
K&N Drop-in, 300M chrome shifter, Limo Tint, PIAA/NokYa lights, & more...
"L" Intake is next!
pictures here
"Help! I have fallen! and I can't get ..... Hey! Nice carpet!"
