11-10-2012, 11:36 PM
#1
Lancaster / Palmdale |
Year: 2004 |
Color: Silver |
316 |
Changed ALL cluster bulbs to LEDs and now car won't start - wtf???
 So today I FINALLY switched ALL my cluster lights to LEDs. I used 25 SMD-LEDs for the main bulbs and 20 SMD-LEDs for the turn signals, one LED for the Cruise light and 2 for the High Beam light. I know LEDs can "confuse" the electrical system & make it act funny because I've experienced this in my Civic and in my bro's Regal. But ALL the car lights (headlights, tails, interior) were on while I was installing the cluster lights, which is strange!! So I finished & tested the cluster lights. They all lit up. I was happy UNTIL... I went to start my car and it won't start! I hear a fast clicking/rattling sound when I turn the key in the ignition that I believe to be the starter. Also when I turn the key, the interior lights flicker at the speed of the clicking/rattling sound. WHAT COULD IT BE? I am trying to rule out the possibility of a dead battery since all the bulbs in my car are LEDs which do not drain the battery and I was able to turn the headlights on so the battery is NOT dead. Maybe I didn't fully connect the cluster? Did I blow a fuse that prevents my car from turning on? I doubt it's the starter. What a coincidence that the day I decide to change the cluster lights my starter goes out. My dad said it could be a relay somewhere but he wasn't specific. Is there anything you guys can think of?
11-11-2012, 12:04 AM
#2
Dain bramaged |
Maryland |
Year: 1995 |
Color: Spruce Pearl |
7,082 |
Sounds like a dead battery. If you had the doors open/interior lights on all day, it can kill a battery. Try giving it a jump/charge.
11-11-2012, 12:08 AM
#3
Year: 2004 |
Color: Silver |
316 |
That's the advice my dad gave me.. I did have the doors open so the map and rear passenger lights were on for about an hour and the head and tail lights too. I live in a desert so its cold right now but I'll definitely try jump starting it tomorrow morning.
11-11-2012, 12:58 AM
#4
Osceola, IA |
Model: ES, 300m |
2,450 |
11-11-2012, 01:02 AM
#5
Year: 2004 |
Color: Silver |
316 |
Originally Posted by micholob
I don't know if this is a joke but I have 3/4 of a tank full.
11-11-2012, 01:10 AM
#6
Osceola, IA |
Model: ES, 300m |
2,450 |
Mhmm
11-11-2012, 01:21 AM
#7
Year: 2004 |
Color: Silver |
316 |
Mhmm
Do you have any other ideas of what could be wrong??
11-11-2012, 01:40 AM
#8
Osceola, IA |
Model: ES, 300m |
2,450 |
I don't know, I reckon.
11-11-2012, 02:42 AM
#9
Greater Pittsburgh, PA |
Model: Intrepid "Superbee" |
Color: PEL Sechs |
14,565 |
There's nothing in the cluster preventing the car from starting or running properly. Sounds like you may have demons elsewhere. Check your starter grounds
Sent from my DROID RAZR using AutoGuide App
11-11-2012, 04:13 AM
#10
Woodbridge, Virginia |
Model: Intrepid SXT |
Color: Red |
448 |
I think your battery is dead. give it a jump.
11-11-2012, 11:17 AM
#11
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
Any luck?
11-11-2012, 02:42 PM
#12
Year: 2004 |
Color: Silver |
316 |
Originally Posted by cdmccul
Any luck?
I gave it a jump start, no luck. I kept trying to turn it on and the battery just DIED. So it looks like the battery MIGHT be the culprit. I have a Duralast Gold battery that was put in in September of last year and took it out opened the vents and each of the 6 holes' fluid level was low so I added distilled water. The battery is currently being charged. In the meantime I cleaned the battery, terminals, battery area and when it charges I'll put it back in and hopefully that solves my problem! I'll check back in a few hours.
11-11-2012, 03:02 PM
#13
Year: 2004 |
Color: Silver |
316 |
If anyone has more ideas of what could be wrong please post them. Thanks.
11-11-2012, 03:47 PM
#14
LH Tinkerer |
East Saint Louis Co |
Year: 2003 |
Color: Silver |
1,404 |
The fast clicking is a dead giveaway that the battery has lost enough ummph to crank it over. Duralast? Is that the Wally World Line? If so, I'd put a charger on it for an hour or so and retest.
11-11-2012, 04:43 PM
#15
Year: 2004 |
Color: Silver |
316 |
Dead giveaway? Ok it's sounding more and more like my battery is at fault. I know Duralast is not the best battery out there but the Gold is supposed to be a little better. It's the AutoZone line of bateries. Anyways, it was in there when I bought the car in June. Next battery will probably be an AC Delco. Battery still charging, will put it back in a bit.
