Originally Posted by austin
i just unplugged them from the throttle body i didnt take the hole component off of the throttle body
also did some research after the fact and came across a site http://www.mobiloil.com/USA-English/...le_Bodies.aspx
it says in this not to 'disturb' these
and will try the removing the negative will post with outcome
thank you
That should help, it resets the engine controller's adaptive memory to zero and wipes any history of a TPS or IAC swing.
The article mentions not to disturb the wires but, if you have the key off or battery disconnected, this won't be an issue. Also, the article doesn't mention how throttle bodies on LH vehicles generally face backwards so cleaning effectively might require removing it completely, plugs and all.
