If it is the tube that connects to the top of the plenum just next to the throttle body, it would have caused a major vacuum leak, which means high idle, loss of idle control, which could possibly cause a hard start. If it is the plastic tube down under the plenum that runs across the back of the engine and connects to a metal line running to the fuel tank, not so much.
