12-21-2012, 06:05 PM
#1
Intrepid Newbie |
utah |
Year: 1994 |
Color: maroon |
1 |
No Heat!!!
I have a 1994 intrepid. This morning I got in it to drive to work, and no heater. Fan works but no heat? Any thoughts?
12-21-2012, 08:51 PM
#2
Osceola, IA |
Model: 300m |
447 |
low coolant level? clogged heater core? stuck blend air door?
12-21-2012, 09:39 PM
#3
LH Tinkerer |
East Saint Louis Co |
Year: 2003 |
Color: Silver |
1,398 |
/\/\/\ My vote is low coolant... i.e. a leak /\/\/\
12-21-2012, 10:33 PM
#4
Lowell, IN |
Year: 1995 |
Model: Eagle Vision TSI PHP |
Color: Char-Gold Satin Met |
1,629 |
Check the thermostat. If the coolant is low still check the thermostat as low coolant can ruin a thermostat.
12-27-2012, 09:44 PM
#5
Planet Earth, Milky Way Galaxy. |
Year: 1995 |
Model: Intrepid ES 3.5L |
Color: Spruce Metallic PPE |
1,748 |
I didnt know that little tidbit of info. Is it a 3.3 or 3.5L? Try adding coolant (if low) and bleeding the system.
Sent from my SCH-I200 using AutoGuide.Com Free App
12-28-2012, 03:42 AM
#6
Intrepid Newbie |
poland |
Model: intrepid |
Color: silver |
9 |
ncie car
12-28-2012, 09:39 AM
#7
Year: 1995 |
1,748 |
Originally Posted by crawfish
ncie car
Why thank you  . Has there been any change in your heat yet?
12-29-2012, 06:36 PM
#8
Intrepid Newbie |
Chihuahua, MX |
Year: 1994 |
Model: Intrepid ES |
Color: Spruce Green Metalic |
54 |
Another solution? I have the same trouble... 3.3L V6 Coolant just changed and thermostat fully working.....
12-29-2012, 08:18 PM
#9
Year: 1995 |
1,748 |
Did you remember to bleed the system? Ask EAGLEESi for instructions.
12-31-2012, 12:08 AM
#10
Intrepid Newbie |
Chihuahua, MX |
Year: 1994 |
54 |
Yep... All done since one week ago... But recently (about 3 days) got this problem... Coolant level is a little above COLD mark and system is fully working, except heater... Maybe by outside temp (about 15°F)?
01-02-2013, 11:30 AM
#11
Intrepid Newbie |
Chihuahua, MX |
Year: 1994 |
54 |
Well, I don't know what my brother did to the heater but now is working... Anyway still failing sometimes..... I insist about outside temp.....
01-03-2013, 04:02 PM
#12
Lowell, IN |
Year: 1995 |
1,629 |
You may have gotten the wrong temperature thermostat and that's why it seems like its the outside temperature. You need a 195 degree thermostat
01-03-2013, 10:27 PM
#13
Intrepid Newbie |
Chihuahua, MX |
Year: 1994 |
54 |
Ok, I'll check that out... How much takes the heater to start heating?
01-07-2013, 11:14 AM
#14
Intrepid Newbie |
illinois |
Year: 1996 |
Color: red |
87 |
Last winter mine wasn't putting out heat, changed the thermostat and flushed the radiator but still no heat. Finally they (mechanic) flushed the heater core and it has worked since.
01-16-2013, 09:48 PM
#15
Intrepid Newbie |
Chihuahua, MX |
Year: 1994 |
54 |
A little late.....
Everything is ok, 195 degree thermostat, no leaks, coolant level just in the COLD position when cold... What could be happening?
