12-29-2012, 02:00 PM
#1
Intrepid Newbie |
Norton,Ma |
Model: 3.2 Intrepid ES |
Color: Blue |
15 |
Stereo Question??
Im installing an aftermarket stereo as we speak!anyone know what the purple and yellow wire on the back of the original CD/Tape player is for?it had a harness that plugged into the back,and also a good spot for the ground wire!Im kinda new at wiring so any feedback would be great
12-30-2012, 04:15 PM
#2
Lancaster / Palmdale |
Year: 2004 |
Color: Silver |
316 |
I installed an aftermarket stereo last month and the stereo came with instructions and it showed what each wire was for. I THREW THEM AWAY THOUGH. Now I wish I hadn't. Hope someone helps you here.
12-30-2012, 05:23 PM
#3
Virginia, U.S. |
10,280 |
Violet/Yellow = PCI bus
Ground (pre-2002, round connector at radio) = Black/Yellow and Black/Brown
Ground (2002+, rectangular connector at radio) = Black/Orange and Black/Tan
12-30-2012, 06:11 PM
#4
Intrepid Newbie |
Norton,Ma |
Color: Blue |
15 |
I did figure that out thanks!sorry if in wrong forum!anyway i hooked it all up and have power just no sound!!UUGGHHH,i installed a Pioneer DEH-X65BT and used a scosche CR012 harness,where does the 3rd plug on the harness go into or is that one not used?Im stumped checked fuses and all wiring 4X  and think i have searched everywhere on the site!
12-30-2012, 06:36 PM
#5
Year: 2004 |
Color: Silver |
316 |
I just took a look at the stock radio I took out of my Trep. The 2 solid yellow wires say "battery/constant" and the solid purple wire says "rear positive" Not sure if this helps. I suck at wiring so I bought a kit on eBay that eliminated splicing/cutting. You might wanna consider getting one.
12-30-2012, 07:02 PM
#6
Intrepid Newbie |
Norton,Ma |
Color: Blue |
15 |
Thanks! I got a kit but im thinkin the wrong one maybe?seen on here it should only be 2 connections i think and i did not by-pass the amp,know the unit is good!anymore ideas anyone?i did not by-pass the amp is that why?thought i would get some sound
12-30-2012, 08:51 PM
#7
Virginia, U.S. |
10,280 |
Sorry - I thought you were asking about CD changer wires.
12-31-2012, 10:26 AM
#8
"Transform and Rise up" |
Waterloo, ON, Canada |
Year: 04 |
Model: Intrepid SE 2.7L |
Color: Silver |
833 |
it could be that your amp (infinity) isn't getting the remote power on signal from the main harness. when I did my stereo the after market only had two connectors... then I ran RCA's to my amps in the trunk then wire back up to the speakers (by-passing all OEM wiring except at the front doors for the front).... there I tapped into the OEM wiring going into the fronts...
Beeble did a nice show and tell
http://www.dodgeintrepid.net/showthread.php?t=178984
On page 2, about half way down there's a pic of the plug I tapped into.. it's located on the passenger side foot kick panel (one location where the infinity amps is located.
I would check that your OEM amp is getting a signal to power on.. if it isn't then connect the remote output from the new stereo to the wire on the harness that connects to your OEM amp..
I've attached some connector pinout diagrams... these are for the connectors that are in your dash..
EDIT: Just to clearify are you looking to by-pass the amp? Also not to sound like a dick but are you sure your audio has the amp?
12-31-2012, 06:49 PM
#9
Intrepid Newbie |
Norton,Ma |
Color: Blue |
15 |
Thanks for the info!Not D!#&*ish at all. Purpose of this forum is questions right?This is the amp i believe there? and i am not trying to by-pass it,only if it makes it sound better or too make it work!got a new harness today,the old one had 3 connections!!odd looking?A Scosche and the new one is Metra with 2 connections.gonna wire up the new one and ill let you know how it works out.Thanks again
12-31-2012, 09:01 PM
#10
Mag-Tard! |
Tiny Pebble, AR |
Model: 300m Special |
Color: Crappy! |
25,716 |
Those pin outs for the 2002-2004 Base radio aren't going to help him in this case. 2002-2004 Base Audio cars didn't have an amp and the wiring isn't shown for it.
You need to connect the amp turn on wire from your aftermarket radio to the Dark Green wire with the Red stripe (car side wiring). That's pin 1 on the black connector you show in your third picture. I don't know what color the wire is on your aftermarket radio but it should be listed in the documentation that came with it. Usually it's a blue wire or a blue wire with a white stripe. Once you hook that up you should get sound.
If you need the pin out connections for a 2000 car with the amp...I can upload them and post them. Let me know if you need them.
__________________
"Just Junk It LLC." Snobby Luxury at it's Worst! Member of theTwin Magnums of DI.net! Perky Jerky for Everyone!! Crazy Rons House of Mega Deals
12-31-2012, 09:20 PM
#11
Mag-Tard! |
Tiny Pebble, AR |
Color: Crappy! |
25,716 |
Here's the three connectors for the radio in your 2000. C1, C2 are the 7 pin Black and Gray connectors. C3 is the single pin PCI Bus connection that you don't need to worry about because you're installing an aftermarket radio. Good luck.
01-01-2013, 08:25 AM
#12
Year: 04 |
Color: Silver |
833 |
Thank you ronbo. I only had the base, ill try to find pin outs for premium
EDIT: nvm. You have them posted. (Future note.... Don't read and reply until body had sufficient cafine intake)
01-01-2013, 08:09 PM
#13
Intrepid Newbie |
Norton,Ma |
Color: Blue |
15 |
Thanks guys for the info!got it working finally.the old harness was not connected to the remote for the Amp,2nd harness was easier and took no time!Heres how it looks,but dont like the dash install kit!Next is some new speakers all over,it sounds really good though.Impressed w the aftermarket deck so far!got an old 10in Eclipse Sub laying around i wanna try to work into the rear armrest behind,that would be cool!!Thanks again for the help
01-02-2013, 09:25 AM
#14
Year: 04 |
Color: Silver |
833 |
Looks nice!.... I didn't like the MTC for the heat so I swapped to ATC ..
