01-11-2013, 05:55 PM
#1
Cleveland, Ohio |
Year: 1999 |
Color: Platinum |
1,642 |
300M with lost key...options?
I have a chance to buy a ruff 300M with a lost key for cheap...cheap....cheap.
If I decide to do this....anyone know
1. Call locksmith to cut and program a key......cost?
2. Change car to a non-skim ignition....possible?....cost?
My concern is condition of engine without hearing it run....but for $400 should I just say WTH?
01-11-2013, 06:08 PM
#2
Come at me Bro! |
Lizard Lick, NC |
Year: 1998 |
Model: Dodge Intrepid |
Color: Go-mango |
28,264 |
Locksmith or dealer can do it, cost to cut key, program, likely in the range of $150 to $200.
Changing to non-skim would likely require an Intrepid SE pcm and bcm, you might lose some features....
Think of it this way, if you spend $400 for the car, and $200 to get the key, is the car worth more than $600 in parts if the engine is toast?
01-11-2013, 06:15 PM
#3
Sudbury, Ontario |
Model: Intrepid SXT |
Color: Bright Silver PS2 |
12,515 |
What year is it? I think either way here you will have to get a hold of somebody that can cut you a key for the car so you can at least remove the key cylinder out of the ignition. From there, you could replace the PCM, SKIM and key with one from a yard car that matches.
01-11-2013, 08:41 PM
#4
Sangudo, AB |
Model: LHS |
Color: Dark Slate Pearl |
331 |
remote start? if so, there is a chipped blank under the dash.
then any cut key will work.
01-12-2013, 08:36 AM
#5
Aylesford, Nova Scotia |
Model: Grand Caravan sport |
Color: silver |
2,425 |
Take the vin# to the dealer with the paperwork (that you own it) they should be able to cut a key.
01-12-2013, 10:19 AM
#6
Cleveland, Ohio |
Year: 1999 |
Color: Platinum |
1,642 |
thanks guys....decided to pass. She is hinting of water pump/belt failure and I just don't want to get into that right now. No wonder the keys are "lost"
01-12-2013, 10:34 AM
#7
Come at me Bro! |
Lizard Lick, NC |
Year: 1998 |
Color: Go-mango |
28,264 |
Yeah, easy way to find out...if they will let you just pop a corner o the timing belt cover and see what it looks like....if the belt is in tact might be worth it....but regardless, any $400 car is a guaranteed money pit.
01-12-2013, 02:18 PM
#8
Leave Nothing Stock. |
Indy |
Year: 1999 |
Model: 300M |
Color: Cypress Pearl Green |
1,258 |
i was going to say, you can program any key to work with a DRBIII. Ive done it a few times at the shop for repos without keys.
01-12-2013, 08:58 PM
#9
LH Tinkerer |
East Saint Louis Co |
Year: 2003 |
Color: Silver |
1,438 |
But, unless he already knows the SKIM pin #, he'll have to get that first.
01-14-2013, 11:08 AM
#10
Nauvoo, Illinois |
Year: 2004 |
Model: 300m Platinum |
Color: Brillant Black |
1,215 |
Unless it's worth that much in scrap.
