01-15-2013, 07:10 PM
#1
Intrepid Newbie |
Russia,Moscow |
Year: 1995 |
7 |
Intrepid 3.3l 1995 problems
Hi. The oil sensor burns on the dashboard where to look what to make?
the turn signal at the left and on the right everywhere and a signal of an emergency stop doesn't burn what to look?
there is no sound signal when the door is open! I concerned an armrest, the sound appeared, now again there is no sound!
Forgive for the text, I translated in the translator!
01-15-2013, 07:16 PM
#2
That rhythm is INFECTIOUS. |
Pickerington OH |
16,885 |
In all honesty - you may want to also post in your native language. Believe it or not, we have some guys here that speak Russian.
01-15-2013, 07:22 PM
#3
Intrepid Newbie |
Russia,Moscow |
Year: 1995 |
7 |
It, oh, is excellent!
If they write to me, I will write in the language!
01-15-2013, 08:26 PM
#4
Come at me Bro! |
Lizard Lick, NC |
Year: 1998 |
Model: Dodge Intrepid |
Color: Go-mango |
28,098 |
I am quite rusty....but....
Zdravstvuitye, dobro požalovat....Введите вопрос еще раз, на русском языке, пожалуйста ..... я постараюсь ответить. В противном случае я познакомлю вас с членом здесь, что живет в Москве....
__________________
Member of The Twin Magnums of Di.net
 Proud sponsor of Just Junk It, LLC.
01-15-2013, 08:32 PM
#5
Planet Earth, Milky Way Galaxy. |
Year: 1995 |
Model: Intrepid ES 3.5L |
Color: Spruce Metallic PPE |
1,749 |
Did you use a translator? If not I have a new respect.
01-15-2013, 08:44 PM
#6
D. Patel, BS-BIO, LPN M-IV |
Westerville, Ohio |
Year: 2004 |
Model: Intrepid SXT |
Color: Inferno Red (PEL) |
7,762 |
Nope, Dan learned Russian as his roots are SPETSNAZ!
01-15-2013, 10:01 PM
#7
Come at me Bro! |
Lizard Lick, NC |
Year: 1998 |
Color: Go-mango |
28,098 |
Yep, roots and 3 years of Russian, alittle rusty, but no translator......hoping Ar4ik can understand my Rusglish!
01-16-2013, 09:04 AM
#8
Intrepid Newbie |
Russia,Moscow |
Year: 1995 |
7 |
!Forgive for my language,i very awfully speak english language.But i can understand the text!
Проблема в следющем!горит на приборной панели датчик давления масла.Не работает аварийка и поворотники!нету звукавого сигнала когда открыта дверь,свет загорается тун-тун-тун- нету.Ничайно задел подлокотник звук появился,потом опять пропал...что делать?где смотреть?как исправить?
01-16-2013, 10:28 AM
#9
Chatt, TN |
Year: 93 |
Model: Eagle Vision ESi |
3,513 |
From what I can gather the oil pressure light is on, The turn signals and flashers do not work, and there is door opening chime.
The other stuff not sure however with the oil pressure light a mechincal test of the engine's oil pressure needs to be confirmed, or jst purchase a new oil pressure sending unit if the engine is not making any abnormal noise.
The flashers and hazards not sure what fuse they are on, however I can look at an FSM later on. However look for a flasher relay and see about replacing that for an easy fix.
Door chime I do not believe is programmable, all in the body control module. In fact, I don't even thing I recall hearing mine ding at me either....I will look into that.
01-16-2013, 01:43 PM
#10
Oshkosh WI |
Model: Intrepid ES |
Color: Green |
274 |
Possible grounding fault?
01-16-2013, 05:49 PM
#11
Year: 1995 |
1,749 |
Mine doesn't ding, unless the key is in the ignition/headlights are on, and the driver's door is open.
Шахта не Дин, если ключ находится в фары зажигания на, и дверь водителя является открытым.
