Originally Posted by tonyeq
Thanks. Any pictures or how-to on changing that out?
There are probably several threads around that address the R+R of a damper pulley. First of which you need to verify that's your problem. Does the damper on yours wobble a lot when running?
Also, you'll need a harmonic balancer puller with three jaws. Harmonic balancer is another name for the crankshaft damper pulley. The ones with bolt holes will not work with our engines.
And, you'll need to find a replacement to put back on there. I am sure there are several aftermarket brands available but, I haven't bought one ever. Perhaps some of the members who have bought before can recommend one that will fit the best. You'll need to post your engine size to get the right one.
