01-24-2013, 08:08 PM
#1
Intrepid Fan |
VT ,, USA |
Model: Intrepid RT |
108 |
Another Horse Power Thread
I just picked up a 2002 RT with only 115,000 miles on it.
It runs good but just doesn't have the power that I expected.
The rpm's seem to run a couple hundred less than my ES at 70 mph.
We also have a 2002 ES with 196,000 miles on it.
It has much better acceleration from 0-60.
Now this power difference is not 0-60 with foot to the floor , I'd say
at more normal driving.
The RT also downshifts when coming into a long hill at 65 , where the
ES does not.
Any suggestions or comments ??
Reason: ---------------------------------------------
01-24-2013, 08:40 PM
#2
Squilly's Jubilant Buttocks |
Holland, MI |
Model: Intrepid ES 3.2L |
14,195 |
So your ES was originally a 2.7L? Did you leave the original transmission? Did you change the final drive in said transmission? I'm pretty sure the answers are yep, yep and nope.
Put a set of 2.7L (or 300m Special) final drive gears on your RT and they'll behave the same.
01-24-2013, 10:45 PM
#3
Intrepid Fan |
Fowlerville, MI |
Year: 1999 |
Color: Charcol |
216 |
Check over and tune it up. I could never get my ex to figure that one out. My old 99 base 2.7 is a hell of a lot faster than her 01 R/T with a 3.5. Then she finally had someone change the plugs and oil.
01-25-2013, 02:12 AM
#4
USA |
320 |
A tune up never hurt. A new air filter, oil change and set of plugs can make a significant difference.
But if beeble is hitting the right note and you're running different final drive gears, that'll be your answer.
01-25-2013, 02:41 AM
#5
Intrepid Fan |
Indiana |
Model: Intrepid r/t |
Color: 2 tone black and red |
203 |
115,000 miles u say.....hmmmm....well my 2000' R/T blew her engine at 116,000....lol....so I wouldn't be pressing it for Camaro SS speeds...lol....baby her till it goes!!!
01-25-2013, 02:44 AM
#6
Intrepid Fan |
Indiana |
203 |
but seriously.....before my motor died a year ago it had 116K on it....the new motor I got was from a 2004....same 3.5 HO...only had 46000 miles on it......but much better feel, better sound, better power and reminds me of when I first got my R/T in 2002 with 46000 miles on her....times takes its toll on 3.5's.....plugs, oil, K&N FIPK intake kit.....it'll definitely help.....perhaps run some SEAFOAM thru the different area, fuel, intake, oil.....it definitely helped my old engine Seafoaming it.....till it blew up that is...lol..
01-25-2013, 05:22 AM
#7
Westerville, Ohio |
Color: Dark Garnett Red |
6,050 |
It's all about how you take care of it. My 3.2 with 102k on it runs better than ever. I decided to have a bit of fun today on the way home and stomped on the gas a few times (no snow on the ground where I did this). Tons of torque steer, quick response, and spinning tires.
I seafoam my oil every few changes and use Mobil 1 every time. I'll do the intake when I'm ready to change plugs again.
01-25-2013, 05:51 AM
#8
Intrepid Fan |
VT ,, USA |
108 |
No ,No , No , factory 3.5 with stock tranny gears
Did the RT come with a lower gear ratio " number " ?
01-25-2013, 05:53 AM
#9
Intrepid Fan |
VT ,, USA |
108 |
I'll admitt that this thread may be a little premature as I've serviced all the fluids
but have not changed the plugs or air filter yet.
01-25-2013, 05:58 AM
#10
Intrepid Fan |
VT ,, USA |
108 |
I hear ya ,,, we've owned many an Intrepid.
This is a very clean no rust southern car but I always question
the use a car gets that has a slap stick shifter.
01-25-2013, 06:07 AM
#11
Intrepid Fan |
VT ,, USA |
108 |
It runs smooth and will be my wifes daily driver so it's really not a big deal.
I just remember driving an 03 SXT with a slap stick and it was very impressive.
Even though I never changed the tranny in the ES , maybe the stock tranny
was replaced with a 2.7 tranny sometime before me.
Reason: ----------------------------------------------
01-25-2013, 06:12 AM
#12
Intrepid Fan |
VT ,, USA |
108 |
I just remember driving an 03 SXT with a slap stick and it was impressive.
A little off the subject of this car but did a 04 Intrepid Police pkg with 3.5
engine come with the lower gears " higher number " ?
I have one of those from a car we parted out.
01-25-2013, 06:17 AM
#13
Intrepid Fan |
VT ,, USA |
108 |
Proper Maintainance is not most peoples priority when it comes to a vehicle.
We've only bought one Intrepid that when I took the oil filler cap off the inside
was spotless , clean , well maintained. Most are all dark with oil varnish.
01-25-2013, 06:42 AM
#14
Holland, MI |
14,195 |
no, I guess I miss-read your siggy, looked like you'd done a swap.
01-25-2013, 07:09 AM
#15
Intrepid Fan |
VT ,, USA |
108 |
Yes , in the SE , still in progress . I probably wouldn't do again.
