09-24-2003, 01:32 PM
#1
Minni-snow-ta |
2,536 |
Replacing windshield washer nozzles?
Are these things just 'snap-in' or ??
09-24-2003, 01:38 PM
#2
Maryland |
Model: Base model; 2.7L |
Color: Metallic Silver |
9,831 |
No. Someone on this site attempted those pretty little washer nozzle lights mod. They had a tough time if I recall.
09-24-2003, 02:23 PM
#3
Planet LX |
5,763 |
They snap in alot easier than they come off. You have to be carefull not to dent the hood around the nozzle while you're trying to pop it off. You might want to try and push one tab at a time, they are located at the front and rear of the nozzle below the hood skin. If you're putting on the ones fastened by a nut you might as well bore a 3/4 or 1" hole directly below the nozzle then use the hole to push the tabs in to remove the OEM nozzle.
09-26-2003, 01:37 AM
#4
Intrepid Newbie |
Elgin, IL |
75 |
I had to cut out a hole under the nozzle to put those pretty little lights on.:( I didn't want to take the chance of denting my hood. Was NOT easy, but it looks cool.
09-26-2003, 11:43 AM
#5
Indiana |
256 |
I disconnected the hose and shot air threw the line and threw the washer fluid tank. Then I shot air threw the nozzles and they were both clogged ,but in the process I blew the hoses off them now when I hit the button it just goes all underneath my hood. oops :| Drilling a hole huh? I might try that.
09-27-2003, 10:07 AM
#6
2 miles from the real Hell, MI |
1,242 |
That's what you get for being a ND fan! LOL!! J/K. Did you put them back on yet?
09-27-2003, 12:51 PM
#7
Saginaw, Michigan |
637 |
When I did mine a while back, I actually took the hard road doing it. I sawed through my hood a little to allow my hands to reach the stems to put the nuts on the actual nozzle. Luckily the stock ones were just clips, so they were easy to get rid of. But to add different style ones was a lot of hassle, yet well worth it.
09-28-2003, 04:31 PM
#8
Abilene Texas |
2,074 |
Yeah, doing the nozzel lights was a pain in the ass. I got a drill bit that was big enough to go through the top of the hood to the engine bay area, but I had to hack at it a little bit just to get my socket to fit in there to tighten up the nut.....still have to file down the metal from drilling it, but I think it was worth the trouble. Running the wires were a pain also, I ran the wire from my switch under the dash and zip tied them, ran them through the fire wall area on the fender, put the ground wire on that screw right next to the hood arm, ran the power wire through the rubber thing that is under the hood, good to go. Worth it in my eyes. I am the ONLY and I mean ONLY second Gen in town with them  DO IT!!!
