02-25-2013, 09:42 PM
#1
Intrepid Newbie |
chicago |
Model: intrepid se 2.7 |
Color: gold |
47 |
02 intrepid trunk
alright first off im 16 and i am new to this site and i a have a question so i just got this 2002 dodge intrepid as a 16th birthday present and i was wondering if any body could tell me if there was a way to get my trunk open it wont tke the key or the button and i would like to use it for sports gear and groceries and things like that so if any one of you great people could help me out that would be great
thanks
02-25-2013, 10:10 PM
#2
Mopar MacGyver |
Ocala Fl |
Year: 1997 |
Model: Sport 3.5L |
8,129 |
Moved to General Discussion (second generation).
02-25-2013, 10:27 PM
#3
LH Tinkerer |
East Saint Louis Co |
Year: 2003 |
Color: Silver |
1,401 |
Do you have fold down rear seats? If so, climb in and pull the emergency handle today and then schedule a fix at the shop of your choice.
02-26-2013, 02:37 AM
#4
Georgia, USA |
Year: 9804 |
Model: Intrepid ES / SE |
Color: PTE / PW1 |
2,428 |
And if you don't have fold-down seats, remove the seats, then continue as above.
02-26-2013, 08:39 AM
#5
May : Back in the office in Indianapolis |
Year: 2004 |
Model: Intrepid(Project 14) |
Color: Light Almond Pearl |
826 |
The bottom rear seat cushion is pressed in place with a U-shaped metal rod
that snaps into a rubber cup in the floor. There are only two.
Run your hand under the front of the cushion and you will find one
on the front of each half of the cushion;
Place one hand on either side of it and pull up with a quick jerk.
Sometimes they are stuck pretty good.
By using two hands there is less chance of bending the frame of the cushion.
Then go to the other side of the car and do the same thing.
Once the cushion is out, you can unscrew the two bolts and two nuts that
hold the seat back in place.
Two outer bolts and two inner nuts; use an 18mm socket.
Once those are out, you can pull out silightly on the bottom while pushing the seat back up.
There are three hooks across the back of the shelf that the seat back rests in.
You need to push the seat back up about an inch to clear the hooks.
02-26-2013, 03:39 PM
#6
Garrison, ND |
Year: 1994 |
Model: Intrepid ESi |
Color: Indy Red Clear PRB |
15,412 |
Welcome aboard! And, Happy Birthday!
You're in the right spot. Post up pictures when you can.
02-26-2013, 05:49 PM
#7
Intrepid Newbie |
chicago |
Color: gold |
47 |
i do have fold down seats but the place i got the trep from kind of jacked the car up and broke the green emergency latch and i dont know where i can take the car without spending too much money
02-26-2013, 05:50 PM
#8
Intrepid Newbie |
chicago |
Color: gold |
47 |
]i do have fold down seats but the place i got the trep from kind of jacked the car up and broke the green emergency latch and i dont know where i can take the car without spending too much money
02-26-2013, 07:19 PM
#9
Year: 2004 |
826 |
Ok, so crawl inside the trunk with a flashlight and 10mm socket .
The catch is bolted to the back of the trunk with just two bolts.
The bolts are just behind or sticking through the carpet.
But before you do that, as you're facing the latch, look for a small cable
(maybe five or six inches long) coming out of the left side of the plastic
latch cover. It's an emergency release for the latch.
If the cable is there, you can grab it with pliers and pull, popping the latch.
03-03-2013, 09:54 PM
#10
Intrepid Newbie |
chicago |
Color: gold |
47 |
thanks TGS i did just that and now i got it open i took the car to pepboys and got that fixed and in the process the car was hit
03-03-2013, 10:06 PM
#11
"Transform and Rise up" |
Waterloo, ON, Canada |
Year: 04 |
Model: Intrepid SE 2.7L |
Color: Silver |
823 |
Dang dude your not off to a good start...hopefully the damage isn't too bad..
03-03-2013, 10:18 PM
#12
Intrepid Newbie |
chicago |
Color: gold |
47 |
the damage isnt that bad its gonna cost quite a few dollars to get it fixed though but the good thing is since ive been saving all my money and had a job i had the money to get it fixed plus do the mods ive been planning on doing
03-03-2013, 10:42 PM
#13
now Omaha, Ne |
502 |
Wow welcome aboard! but definitely sorry about these hassles.. There's a LOT of good info and helpful people here - so feel free to ask all the questions you want.
Good Luck!
03-04-2013, 08:25 AM
#14
Year: 04 |
Color: Silver |
823 |
a lot of common mods are installing Evic, exhaust, autostick and converting from MTC to ATC... but there are many others... just surf through the performance section and you will get some good ideas... as most of us here have done them feel free to ask away...
03-04-2013, 09:28 AM
#15
LH Tinkerer |
Year: 2003 |
Color: Silver |
1,401 |
Glad to hear it all worked out. Now, I see you are one of those "Normal" kids who is grateful about getting a car, any car just for turning 16. I think we must have dropped my kids on their heads since none of 'em want to drive any LH I have offered.
