10-02-2006, 07:16 PM
#1
SpokaneWA |
699 |
Error codes, list?
I did a search and couldnt find the info, is there a list for the codes the check engine light flashes with the on off on off on method? Anyways I think I'm getting the following codes..
12, 35, 25, 32, 55(end of seq)
btw car is experiencing high idle 3000rpm/1300 in drive, weird shifts, bump shifts
10-02-2006, 07:21 PM
#2
Southwest, UT |
3,041 |
10-02-2006, 07:28 PM
#3
SpokaneWA |
699 |
32** Open or shorted condtion detected in the EGR transucer solenoid circuit
32** Required change in air/fuel ratio not detected during diagnostic test
EDIT
25** Open or shorted condtion detected in one or more of the idle air control motor circuitsCLEARED
35** Open or shorted condition detected in the control circuit of the low/high speed radiator fanCLEARED
10-02-2006, 07:30 PM
#4
SpokaneWA |
699 |
thanks strong gt, so I just replaced the IAC yesterday, so what does it mean by open or shorted condition, what would I look at to fix that code? does the EGR one mean the EGR valve needs replaced? This would account for my high idle, but what else would I probably need to do to fix it? Just replace the EGR parts?
10-02-2006, 09:21 PM
#5
SpokaneWA |
699 |
unplugged batt for 15 mins or whatever, now the car revs from 1200 to 2000rpm when it downshifts into first at 10-15mph, wtf, then the car kinda shutters trying to get rpms down, all computer issues?
10-02-2006, 10:00 PM
#6
Southwest, UT |
3,041 |
Since you cleared the computer, what codes come up now?
10-02-2006, 11:12 PM
#7
SpokaneWA |
699 |
disconnected battery again, all seemed like it was, with the hesitant first and second shifts, but now traveling above 60 like 63-65 the gear shifts up and down randomly, would this be fixed by the ATF+4 and and TCM upgrade of the software?
--edit--
after third disconnect of battery those other codes were all cleared now it just reads --
--12 Battery disconnects r0x
**32 Open/shorted circuit detected in the EGR transucer solenoid circuit
--55
so replacing the EGR is at hand I guess, I saw a how to last night but cant find the link anymore
