Started the Trep this morning, and the throttle wouldn't work. Car was running, but when I pressed the gas, nothing happened. RPMs stayed the same. Same thing in all gears. So I turned it off, waited a minute and restarted it, and everything worked fine. Anyone seen this behavior before? Maybe a throttle position sensor?
also run some seafoam through her lungs!, (The Intake that is,lol), or osme creeper in the IAC sensor, and TPS sensor, shes probably dirty, and complaining about being cleaned out!,;) Hope this helps!
