It sounds like it is at the front where the block, timing cover and pan all meet.. When you replace the gasket this area needs a good bead of RTV sealant.. If you loosen a few of the front pan bolts and the horizontal bolt you should be able to inject a bead of sealant into the area and tighten back up to seal the current leak...
