Should be, yes.
Sent from my SM-G996U using Tapatalk
Also I’d you need some suggestions on quality aftermarket parts suspension wise, I’d look into Detroit Axle. They made my steering rack I replaced about a year ago now and it’s been working great for me. They were also really good with returns when I didn’t have quite the right part. I think you do have to send back the core if I’m not mistaken. I highly recommend them.Are the suspension parts and wheel rotors and such interchangeable between a 2000 intrepid and a 2002 Concord?
I will warn you of a big thing when it comes to brakes with Intrepids. I have a 1999 Intrepid SE but it had 16 inch wheels. They are add on wheel package from Chrysler but the knuckle is a 15 inch knuckle. So buy 15 inch rotors as the 16 inch rotors will not fit. I learned the hard way. I also had to replace the knuckle and put a 16 inch one on and had it running for a while. I just did all the suspension from another car with low mileage in great shape so I just took all the front end parts and swapped them. The car has never ridden better. I even added camber adjustment bolts to make sure they could really dial in the alignment.Are the suspension parts and wheel rotors and such interchangeable between a 2000 intrepid and a 2002 Concord?
Suggestion: Always have the alignment shop agree before you authorize the alignment that they will provide you with a "Before" and "After" printout of all of the alignment numbers (including front cross-camber, front caster, and front cross-camber) - even the ones that aren't adjustable. Most shops are set up to do that as part of their published alignment price because people have become more educated about this and it is now expected/demanded by many customers. AND inform them of any parameters that weren't adjustable from the factory but that you've made adjustable (for example: front camber and cross camber, and rear camber in addition to rear toe) and get their agreement to adjust those to bring things well within the published specs. You can't assume that they will give you the printouts or that they will adjust the parameters that you've made adjustable unless you discuss it with them and get their agreement - and that has to be done before you authorize the work to be done. If they aren't willing to do those things, take it to another shop that will....I even added camber adjustment bolts to make sure they could really dial in the alignment.
I can attest to this. I had to align my own car myself on one of those fancy alignment machines. It was a total pain to do, especially since I didn’t have any of the special tools that you needed. Thankfully, it was easier for me because I had the tie rod ends replaced within the last five years so while there was still corrosion, it wasn’t as bad as it normally would get. I definitely agree with getting a before and after alignment sheet from, the mechanic doing the alignment because sometimes by the amount it’s off is not going to really damage anything. Like my steering wheel in my car is just a little bit off-center from what I remember but it’s really not the end of the world.Suggestion: Always have the alignment shop agree before you authorize the alignment that they will provide you with a "Before" and "After" printout of all of the alignment numbers (including front cross-camber, front caster, and front cross-camber) - even the ones that aren't adjustable. Most shops are set up to do that as part of their published alignment price because people have become more educated about this and it is now expected/demanded by many customers. AND inform them of any parameters that weren't adjustable from the factory but that you've made adjustable (for example: front camber and cross camber, and rear camber in addition to rear toe) and get their agreement to adjust those to bring things well within the published specs. You can't assume that they will give you the printouts or that they will adjust the parameters that you've made adjustable unless you discuss it with them and get their agreement - and that has to be done before you authorize the work to be done. If they aren't willing to do those things, take it to another shop that will.
Also: The factory front toe adjuster sleeves on our cars are of poor design and often become unadjustable due to corrosion and cracking, which results in severe binding. It is very advisable to replace your factory toe adjuster sleeves with the aftermarket type that have the large hex wrench grip for ease of adjustment. Most aftermarket companies make two versions of the sleeve: The inferior factory knurled-grip type, and the much-improved hex grip type (see the below photos of the two types from the Rock Auto web site). Get the hex grip type. If you don't do that, many shops won't tell you that your original factory sleeves are corroded and/or cracked to the point that they are no longer adjustable, and will leave your toe unadjusted. Hard to believe, but it's a fact. Replace them with the improved hex-grip design ones (and grease the inner and outer threads before installing them to prevent future corrosion and binding) and let the shop know that you installed good ones so they will not be tempted to leave them unadjusted and make up a bogus excuse after-the-fact. Getting the "before" and "after" printouts will also help keep them honest in that regard.
TOE ADJUSTER SLEEVES (TRW brand shown)
Inferior factory (knurled grip) design:
View attachment 43330 View attachment 43332
Improved (hex grip) design:
View attachment 43331 View attachment 43333
