65K miles
Upon just having the timing chain tensioner fixed, the car will not start with the cam position sensor connected.
It starts fine with the sensor disconnected. The sensor is a new one. It was running before the tensioner job.
Mechanic did not disconnect chain, so timing relationship is the same.
All connections checked so far, Diagnostics keeps showing bad cam sensor.
Tried the old one as well. It ran on the old one before the new one was replaced. Will not run on either sensor.
Anyone?
Anyone?
