My first code was p0132 so I installed a Bosch sensor. The car was ok for a day and then I got code p0152 so I replaced the second sensor. Now I get the two codes and when I switched sensors, I'm back to getting code p0152.
HELP!!!
(if this in the wrong section, please put in right place please)
yep, but just got word from dealer that pcm needs replacing. New in Canada is $700.00-used $400.00.
Was also told that new one has to have software insalled at a further cost.
Is the car still driveable with the 02 sensor malfunction?
yes its still driveable. but u wont pass inspections and u will get crappy gas mileage if any of the sensors are bad
Thanks for the info. Now another question about the pcm. If I buy used, will it work or will the dealer have to program it. A wrecker has one with the same part number as mine but the dealer says that the computer has been upgraded 3 or 4 times since 2002? I commute 1.5 hours each way , so I might get better mileage from my 5 liter chev truck.
Justin said:
Instead of just linking people that sticky..
Why not point them in the correct direction, as well?
Or,was that another thread?-
Yes it was.
Your post was invaluable in helping others, also!
OOOPS!!Wrong link!!
I had found the part numbers for the sensors--
This link! http://www.dodgeintrepid.net/forums/showthread.php?t=69119
Pointed him to part numbers...might come in handy...
Didn't see any others volunteering any info, at that point in time.
Didn't even mention the search button!
