Tonight i was scanning my 97 3.5 intrep sport cause the engine light was
on so my scanner posted po-160 02 sensor bank 2 .does this mean
the top passenger side of the car at the front of the exhaust the bank issue
sort have me confusedSecond ? it also posted a po-302 misfire / multipul
misfire. any suggestionwill help with this on oh almost for got when the is at
a light it start to shake noticable but driveing you can't tell
P0160 is the drivers side O2 sensor. P0302 is cylinder #2 mis-fire. Could be the #2 plug, wire, injector, or manifold leak.
In any case the O2 sensors should be changed as a set. They are all the same age and have seen the same amount of use.
