1 - 20 of 32 Posts
· Registered
My Intrepid is broken again, big shock. This time it's been fine running after a cold start but gradually, more and more slapping from the timing chain happens. I haven't driven it in nearly 5 months out of an abundance of caution but I wanted to ask if it was something that I could tackle myself in my garage. I'm super nervous about messing with the timing on it and I know it could just be a tensioner but Im replacing the chain, guides, and sprockets as well because its got 121k miles, and it's probably time anyway. I haven't done any major mechanical work like this before so I was wondering if this was something that would be good to get my feet wet with.
I was also more or less concerned about doing the valve seals while the chain is off (because I believe that they are bad and causing some noticeable oil consumption) but after reading up on the repair procedure, Im relatively nervous about using 90-100psi of air in one of the cylinders. Is it possible to get to replace the valve seals without having to use compressed air?
Oh 2 more things, are there any special tools required for either of these tasks besides the timing chain tensioner tool, and is there any work that I should do while Im in there? Just trying to be prepared before diving into this project. FYI the water pump is updated and was changed 50k-60k miles ago.
Thank you for your time!
· Premium Member
There is a good alternative to using compressed air to keep the valves from falling into the cylinders when replacing the valve stem seals. In fact it is less risk for two reasons.
What is this method you ask? It's putting the cylinder you want to work on at BDC, taking some small rope (Ø3/16" woven polyester from Walmart or big box store is ideal) and pushing it thru the spark plug hole - keep feeding it in until the cylinder is mostly full, then turn the crankshaft CW by hand to compress the rope up against the cylinder head. You don't have to worry about trying to get every last inch of rope stuffed in - just keep pushing it in until it is resisting taking anymore - that should be plenty, and you don't have to turn the crankshaft very hard against the head - the piston just needs to be pushing the wad of rope upward moderately hard to keep the valves from dropping.
The advantages of this method are (1) you don't have to have an air compressor or worry about losing electricity or the compressor failing in the middle of the job, and (2) you don't have to worry about moisture from the compressed air condensing out inside the engine and causing rust or swelling of carbon deposits creating a piston-to-head interference (that actually happened to me one time).
So I definitely advise using the string method rather than compressed air.
· Premium Member
You don't really need the tensioner tool. You can improvise with a small pointy object, like a small jeweler's screwdriver, to depress the ball check valve in the tensioner to drain the oil out if it. (You're not replacing the tensioner with a new OEM one?)
You'll need a valve spring compressor that will fit in the cramped spaces around the valve springs on your engine. This is a good one:
You might re-read your previous thread for additional suggestions:
· Registered
Discussion Starter · #5 ·
You don't really need the tensioner tool. You can improvise with a small pointy object, like a small jeweler's screwdriver, to depress the ball check valve in the tensioner to drain the oil out if it. (You're not repkacing the tensioner with a new OEM one?)
Thanks for the rope trick and the suggestions! And I probably would replace the tensioner because I think that’s acting up causing my issue but I’ll just replace the chain, guides, and sprockets while I’m there. Appreciate all your help! Thanks so much!
· Registered
If your doing your timing and components and want to do the valve springs why not just take the head off and throw a new head gasket in at the same time i asume your replacing the secondary timing chains too
· Registered
Discussion Starter · #8 ·
Might not be a bad thing. Im going to get a gasket kit with head gaskets and such so I might do that as a preventative measure. Plus it would make it much easier to do the valve seals.
· Registered
I just mentioned it because i just put in a new timing chain and timing component oil pump water pump new valves lifters and valve seals. If your already doing the timing stuff its not really that muchvextra work to just put in a new head gasket and while you have the heads off you could just pick up a cheap valve compressor so its easier to put in the valve seals. I picked up a valve compressor off Amazon for like $25.
· Registered
Discussion Starter · #10 ·
Well I was not going to do the water pump or the oil pump due to the added costs but maybe I should. It wouldn’t hurt I think since it’s just an extra couple bolts to get them replaced.
· Registered
I just did all that because my water pump went out so i figured since i have to tear my engine apart anyway i just replaced every internal part and gaskets
Motor vehicle Vehicle Auto part Electric blue Automotive air manifold
· Registered
Discussion Starter · #12 ·
I just did all that because my water pump went out so i figured since i have to tear my engine apart anyway i just replaced every internal part and gaskets View attachment 43060
That’s good. My water pump was replaced with the updated design 50k-60k miles ago so I didn’t think I’d need to replace it quite yet though it couldn’t hurt. It’s just going to hurt my wallet so much more.
· Registered
If you already replaced it with the updated one you shouldn't have to replace it again, i just had to replace mine with the updated one because the gasket gave out that stupid rubber thing on the metal gasket was in pieces and was causing me to have sludge
· Registered
Discussion Starter · #14 ·
Ah ok. I’m glad it’s an item that doesn’t need replacing now. I didn’t really think about replacing the oil pump though. If it’s not too much extra I think I might do that.
· Registered
They aren't too bad in price. Iv been a mechanic since the early 90s . Usually when i crack an engine open i just replace everything internal that way i know its all brand new and i shouldn't have to open my engine back up.
· Registered
Discussion Starter · #16 ·
Yea that’s what I was going to do. I know the job is a pain in the backside so I want to do as much as possible to avoid having to do it again. I’ve worked as a mechanic for not nearly as long but long enough to know I don’t want to do anymore. I consider mechanics as a sort of hobby and I wasn’t liking doing mechanic work anymore. I didn’t find it enjoyable anymore and along with other factors allowed me to terminate my employment. I’m so glad I did because now I can just focus on my own car and what it needs.
· Registered
I used to set up cars for racing i used to work on lowriders doing hydraulics and NOS stuff like that. But since i got injured and put on disability i cant do it as much as i like to. I love working on engines , i had my own shop in Minneapolis back in the day
· Registered
Discussion Starter · #18 ·
That’s really cool to hear man! I think the most interesting thing I worked on in my time was a minty MazdaSpeed Miata (that’s the one with the factory turbo) and I’ve done things on 6 speed mustang as well. But mostly it was a blur of f series trucks and crossovers. I worked as a lube and service tech at a Ford dealer.
· Registered
Iv done mostly cars, i had a inline 4 cylinder geo storm that i raced a 89 camaro and i beat him by 2 blocks
1 - 20 of 32 Posts
